Recessed Lighting In Outside Sofit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 11:54 AM   #1
Recessed Lighting in Outside Sofit
Hello,
Ok, I have a two switch panel in our entry/living room. One is a dimmer that controls two lights on my porch and into that same dimmer is fan wiring for a fan receptacle on the porch but we have no fan installed so they are capped. Next to it there is another switch that would control a fan inside the entry/living room but we have no fan there either so it's a useless switch right now. What I want to do is place 3, 3" recessed lights in our sofit off of our porch on a seperate dimmer. I've got all the hardware I need (i.e. the lights, 50' of 12/2 Romex, dimmer switch, 3 switch electrical box etc.). I guess my question is, I want to add another switch next to the existing two switches and can I just tap in to the 'Hot Line and and run a daisy up the wall and into our crawl space to the 3 new lights? Let me know if you need any more info and I can provide pics later if you need. These switches are on a 20amp breaker.
darveaux is offline   Reply With Quote
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 11:53 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
