Recessed Lighting Layout/spacing - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 03:50 PM   #1
recessed lighting layout/spacing
I'm going to be installing recessed lighting in the living room & kitchen. Can someone tell me what the spacing between lights needs to be so I know how many I need? Thanks.
acerunner is offline   Reply With Quote
Old 09-20-2010, 04:08 PM   #2
Licensed electrician
Rewards Points: 1,236
You should probably start by reading the California Title 24 that has the energy efficient lighting requirements for kitchens so you will know what your options are.
After that your spacing will be affected by ceiling height, bulb type, room usage, work surface height, type of lighting etc.
Old 09-20-2010, 04:27 PM   #3
I know the requirement. Its 50% of lighting wattage in kitchen must be from high efficient type, flourescent, LED, low-voltage, etc., and dimmable. No problem there, I plan on installing low-voltage lights.
Ceiling height is 8ft, for general lighting. Exact bolt type is TBD.
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 12:53 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 10:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 03:52 PM
