Recessed Lighting - Kitchen - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 09:49 PM   #1
Rewards Points: 33
I am redoing our kitchen and redoing all of the lighting. Kitchen is about 10' x 13' with 8' ceilings. Base and wall cabinets on 3 of the walls. One wall has an outside window (sink under it). Cabinets are off-white/antique. Dark gray granite counter tops, and gray tile flooring.
I want to do recessed lighting in the ceiling that follows the flow of the counter top. Would like to put them all on a dimmer. Plus I'd like to single out a light above the sink on its own switch and possibly one above the stove on its own switch. I'm ripping out the ceiling and will have open joists, so I have room to install whatever.
My first idea is go LED. How are the LED recessed lights now? Any recommendations for them? 4" vs 6"? Any gotchas I should look at for?
If not LEDs, any recommendations otherwise?
My normal for installing recessed is the normal 6" with white trim. I'm looking to do something different in the kitchen.
jgrohol is offline   Reply With Quote
Old 04-10-2013, 06:02 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
WHY mess with what works??
NO WAY I'd use a proprietary LED light at this time. Just use regular cans and use LED lamps if you want.
Also, I feel 4" cans are far too limiting as far as lamp selection and light spread goes. If you did go with them you'd need to use more of them than you would 6".
Old 04-10-2013, 06:13 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
4" cans are not designed for general room lighting IMO. Go with 4-6 6". I do like the Cree LED trims. The cans stay the same, it's an all in one trim/lamp combo.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (04-10-2013)
Old 04-10-2013, 07:54 AM   #4
Rewards Points: 13,446
What's above that area? If it's an attic make sure to use I/C, air tite cans.
Why a dimmer?
The house I live in now had one and it never once got dimed, I replaced it with a reguler switch and the little lady never missed it.
We use the under cabinet lights as a night light.
Old 04-10-2013, 02:31 PM   #5
Rewards Points: 150
I have the cree 6" and 4" LED lamps (in regular Halo cans) and really like them a lot. As others have said, think general purpose and task lighting. 6" cans evenly distributed in ceiling for general lighting; two 4" cans over sink area and two 4" cans over cooktop (cooktop usually has a hood with built-in lighting). Then, some sort of under cabinet lighting for countertop tasks (as stated, also make great night lights).
silversport is offline   Reply With Quote
Old 04-10-2013, 11:55 PM   #6
" Euro " electrician
frenchelectrican's Avatar
I have used Cree recessed LED can units and they seems work very well for most purpose and their brightness is pretty even thru no " hot " spots.
I did use the European Spec'ed verison of Cree recessed luminaire units they have about the same brightness between 60-75 watts indentscent bulbs.
I do belive they can come in two " colour " format one is 4100 K aka cool white while the other verison is about 3200-3500 K more like warm white colour the cost for either verison is the same.
But they do have higher wattage verison but I do not know how easy you guys can get them in state side but in France I can get them pretty easy.
Merci,
Marc
Kitchen Recessed Lighting is it Dangerous naty0629 Electrical 2 05-10-2012 07:43 AM
Need advice for 50-watt recessed lighting in the kitchen mystiky Electrical 3 04-26-2011 10:16 PM
What kind of recessed lighting and bulb? Sardinia Electrical 2 01-28-2011 11:03 AM
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 04:30 PM
Insulating IC recessed lighting. topher0524 General DIY Discussions 4 02-10-2009 06:03 AM
