Recessed Lighting Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2012, 10:44 PM   #1
I'm remodeling a family room primarily used for watching TV. I've seen a number of reccomended lighting layouts on this forum but my primary concern is.....a duct "chase" that runs along the ceiling for the floor above. (I've attached a layout) If I center the cans between the wall and the chase it brings the can on that chaseside of the room 4'6" from the wall and I'm concerned the area beneath the chase will be dark. If I move the can closer to the chase, I'm afraid the depth of the chase will block the light pattern and I will still have a dark spot ??
I was going to use 6 cans, 50watt Par30, Is this adequate ? or should I shift the layout so I can add two more smaller cans as accent lighting on the TV / Cabinet wall ? (eight larger cans seemed to be too many) Should I consider using LED ? Regardless of PAR or LED, trims apparently make a big difference in light distribution. I'm a little confused with all of the options
Any suggestions would be geatly appreciated.
Bruce50 is offline   Reply With Quote
Outdoor Recessed Lighting cbzdel Electrical 4 06-08-2011 12:32 PM
Need advice for 50-watt recessed lighting in the kitchen mystiky Electrical 3 04-26-2011 10:16 PM
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 11:23 AM
Recessed Lighting - Which Fixture? allen1466 Electrical 2 12-29-2009 09:42 AM
Other Options For Recessed Lighting Bulbs jte1130 Electrical 1 11-07-2009 10:57 AM
