Recessed Lighting - IC Or Non IC - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2007, 05:08 PM   #1
Recessed Lighting - IC or Non IC
Hello
I've decided on using some 5" lights from Halo (new construction) with the eyeball trim. They (Lowes) have both IC and Non IC units and almost the same price.The joists 16" o.c and with R30 Batt Insulation - Faced. Is it better to get the "Non IC" just to be safe or does it matter? I'm probably going with the small 50 watt Halogen bulbs and all will be on a dimmer.
Kenny J
Stargazer is offline   Reply With Quote
Old 10-15-2007, 05:18 PM   #2
Electrician philosopher
Better, much better to get the "ic".
Andy in ATL is offline   Reply With Quote
Old 10-15-2007, 05:23 PM   #3
Licensed Pro
Andy is right. If you have insulation in the joist bays, IC is the ONLY way to go.
Old 10-15-2007, 06:15 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
I don't get it.
If there is insulation present how can a non-IC (In Contact) can be "safer"???
Listen to the others.
Old 10-15-2007, 06:56 PM   #5
Electrician
Not sure about everyone else, but where I live we actually have energy/building codes, so to remove the insulation for a non-IC type can would be a violation, not only that, why on earth would you want to raise your heating/cooling costs?
chris75 is offline   Reply With Quote
Recessed Lighting In Basement Rifeman Remodeling 12 09-06-2007 01:26 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
recessed lighting automation cesar333 Electrical 3 12-28-2005 08:54 AM
