Recessed Lighting - How Many Per 20amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2007, 06:55 AM   #1
Rewards Points: 150
Recessed Lighting - How many per 20amp circuit
How many 65w light's can I put on a sinlge 20amp circuit?
I will be adding 2 string's of 4 (each on their own dimmer). Should I feed each dimmer with a seperate circuit (I have the space) or use 1 circuit for all 8?
dcd22 is offline   Reply With Quote
Old 08-27-2007, 08:12 AM   #2
IIRC it's about 10 lights per 20 amp breaker
The Dimmers have a wattage rating (typ. 600w IIRC)
mdlbldrmatt135 is offline   Reply With Quote
Old 08-27-2007, 08:14 AM   #3
Rewards Points: 150
Yes, but he dimmer switch also has a limitation...most are in thre 600 watt range. And you really don't want to max out that switch.
JGarth is offline   Reply With Quote
Old 08-27-2007, 08:28 AM   #4
Licensed Pro
Use one circuit for all 8. You're talking about less than 5 amps load for 8 lights.
Old 08-27-2007, 08:36 AM   #5
Rewards Points: 150
Each string (2 string's each with 4 - 65w light's) will be on it's own dimmer (600w rating).
So, if I am reading correst, I can feed each dimmer from 1 - 20amp circuit. Each dimmer will have 4 - 65w can's conected to it.
If I do this, I will be ok?
Old 08-27-2007, 08:47 AM   #6
Rewards Points: 150
You are NOT reading it correctly...
ONE 20amp ckt is sufficient......
Old 08-27-2007, 09:12 AM   #7
Rewards Points: 150
I guess the way I was typing it was different then the way it came out but that was my understanding.
I am good now, a single 20amp circuit for 8/9 65w recessed light's (fed by 2 dimmer's) will be sufficient.
Thanks for the info!
Old 08-27-2007, 09:16 AM   #8
Rewards Points: 150
Kind of...
not fed by two dimmers,
SWITCHED with two different dimmers.
Old 08-27-2007, 09:18 AM   #9
Rewards Points: 150
I will get the "lingo" right one of these day's!
Thank god someone is doing this for me (friend who is retired electrician)!
I am sure he know's, but not as available as people on these board's and I like knowing myself also.
Thanks again!
Old 08-27-2007, 05:34 PM   #10
Electrician
Your allowed 2400 watts on a 20 amp circuit... and you could always buy 1000 watt dimmers if needed...
Personally, I would have saved myself some money and wired everything in 14awg...
And just so your aware, you could have (9) 65watt lamps on a single 600w dimmer...
chris75 is offline   Reply With Quote
Old 08-27-2007, 05:36 PM   #11
Electrician
If its rated for 600watts what would be the problem in maxing it out?
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
20amp circuit hammerhead Electrical 4 08-20-2005 08:10 PM
