Recessed Lighting Frozen - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 09:08 PM   #1
Rewards Points: 160
recessed lighting frozen
hi i have 4 6 inch LED can lights IC rated in my living room that i hooked up and i had to go through my attic to wire it since i live in a ranch. i didnt put the insolation back over them last night and it got in single digits last night and i went back up there today and they had frost on them! i covered them back up with the spray in insolation. is that ok to do since they are IC rated??? i put nm connectors on each can to hold the wires and so they are pretty well sealed. i just dont want them to get cold and condensate and get water inside and have something real bad happen, thanks
jhack836 is offline   Reply With Quote
Old 01-14-2013, 09:12 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If the cans are installed "in" and insulated attic, the cans should also be air-tite.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
joecaption (01-14-2013), NJMarine (01-15-2013)
Old 01-14-2013, 09:51 PM   #3
I hope you don't mean the spray foam type insulation. That could be a problem. Not a condensation problem. possible fire hazard problem.
Spray fiber insulation is no problem.
You could also wrap them in fiberglass insulation bats if you are still having problems with condensation.
parman is offline   Reply With Quote
Old 01-14-2013, 10:23 PM   #4
Rewards Points: 13,978
I'd also be wondering if you had enough venting in the attic.
To have frost you need moisture.
oh'mike (01-15-2013)
Old 01-15-2013, 05:26 AM   #5
DIY staff
Rewards Points: 7,174
Bury them in insulation and check the soffit vents----baffles should be letting in light at the soffits--if not--you need to get them installed---
Old 01-15-2013, 05:34 AM   #6
Rewards Points: 160
what you mean by "in"? the whole attic is insolated and yes they are air tite as well
Old 01-15-2013, 05:35 AM   #7
Rewards Points: 160
no it is the spray in insolation, not the spray foam
Old 01-15-2013, 05:36 AM   #8
Rewards Points: 160
yes i have baffles. i think i have more than enough vents in my soffit as almost every other bay i can see light through
The Following User Says Thank You to jhack836 For This Useful Post:
Old 01-15-2013, 05:37 AM   #9
Rewards Points: 160
i have plenty of venting it is just freezing up there even to stick your head up there, so isnt that a good thing as i dont have much heat loss?
Old 01-15-2013, 06:12 AM   #10
DIY staff
Your attic sounds good---Just look in on it over the winter and make sure there is not a condensation problem----
That frost might be caused by a very high humidity day---or could be a sign of improper ventilation--Keep an eye on it over the winter----
Old 01-15-2013, 08:42 AM   #11
Soffits are only 1/2 of the equation. What goes in must come out.
Cold is good in an attic.
Old 01-15-2013, 08:58 AM   #12
Rewards Points: 1,536
Also check for excessive leakage of inside air up into the attic. Recessed fixtures in the top floor ceiling are easy exits for inside air. For IC rated fixtures you might put an extra blanket of insulation up in the attic over the spots where the lights are located.
Old 01-15-2013, 02:26 PM   #13
Rewards Points: 160
yup its real cold up there. i have 4 vents on the top but this spring im going to tear them out and put a ridge vent in. the lo omni roll. i used to be a roofer and did alot of roofing and soffits so i have a good idea how it works
Old 01-15-2013, 03:49 PM   #14
Rewards Points: 160
i dont think there is a condisation problem. so signs of mold or and signs of moisture anywhere, deck boards and rafters are very clean which is always good!
Old 01-15-2013, 05:09 PM   #15
DIY staff
As a one time roofer---you are a good judge of the health of a roof and attic----cover those well and call the job done---
Help with Replacing Recessed Lighting from the 80's scubakathy84 Electrical 2 11-03-2012 04:57 PM
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
Recessed Lighting Layout - HELP foxwoods321 Electrical 12 02-24-2011 09:32 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
