Recessed Lighting Design Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 08:39 AM   #1
Just call me Andrew
Rewards Points: 1,020
Recessed lighting design questions
I have been commissioned, free of charge of course, to install recessed lighting in my parents' family room. It is replacing a single fixture with four 4-foot fluorescent lamps.
That being said, I have NO idea how to properly lay out recessed lights. I am waiting for the exact measurements, but here is what i can guess:
Room size: 20' x 12'
Ceiling height: 8'
One thing I have noticed in other peoples' houses that I do not like is when there are too few recessed lights, which forces them to have to be very bright (and piercing) to adequately illuminate the room. I would err on the side of more fixtures, and lower-wattage bulbs (or a dimmer) to make more even, soft light.
How do I know what size fixtures to use? How far apart to space them?
Also - are there any fancy (dual) dimmer switches that would allow me to split the lights in half without having to run an extra hot from the switch? I know lutron makes a switch that allows you to control a fan & light independently with only 2-conductor wire (with a canopy module), but I cannot find one that is meant to convert to two dimmers.
Thanks!
Edit - rough sketch of the room below:
Andrew
secutanudu is offline   Reply With Quote
Old 07-05-2011, 10:26 AM   #2
Licensed electrician
Rewards Points: 1,634
Andy,
I might consider an assymetrical layout with multiple switches. You might want to consider 6" with a baffle trim and a flood PAR bulb. You could use a 6-8' center between lights. I would try to put them over the sitting areas so you have good light to read. Near the TV i would have a separate switch so you don't get screen glare.
Old 07-05-2011, 10:31 AM   #3
Just call me Andrew
Thanks, Jim. Think you could provide some more specifics on how you'd lay out the lights?
Andrew
Old 07-05-2011, 10:37 AM   #4
I might consider 3' off the long walls and 4' off the short wall with 6' in between.
Old 07-05-2011, 10:50 AM   #5
Just call me Andrew
So, two rows of 4 lights each? I was wondering if I should do 3 rows. Maybe that's overkill...
Andrew
Old 07-05-2011, 10:55 AM   #6
It works out to 2 rows of 3.
One at 4', the next at 10', the third at 16' with 4' to the wall for the total of 20'
Old 07-05-2011, 11:08 AM   #7
Master Electrician
Rewards Points: 3,874
Is this a suspended ceiling? If not, the layout will depend upon ceiling joist layout, ductwork, piping, etc.
brric is offline   Reply With Quote
Old 07-05-2011, 11:11 AM   #8
Even with a suspended ceiling you could have obstructions we have no details about. This is why I lay them out in a CAD drawing first.
Old 07-05-2011, 11:36 AM   #9
Just call me Andrew
It's a drywall ceiling, and the joists run parallel with the short wall (left to right in the picture). Shouldn't be any plumbing in that area. There are really no obstructions to speak of.
Andrew
Old 07-05-2011, 01:00 PM   #10
Just call me Andrew
Just got the measurements of the room, I was a bit off, it's 17x16.
I just went to a lighting store, the guy there suggested a normal fixture (maybe with fan) in the center of the room, then 6 cans around the perimeter (like what Jim suggested).
Maybe put the fan/light on one switch, the recessed on another. Thoughts?
Andrew
What kind of recessed lighting and bulb? Sardinia Electrical 2 01-28-2011 11:03 AM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
Ceiling Fan and Recessed Lighting with No Attic Access...Ugh. caps84 Electrical 1 08-06-2009 10:09 AM
Recessed lighting for 15 amp circuit jacads Electrical 5 03-12-2009 12:12 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
