Recessed Lighting Clips - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 02:06 PM   #1
recessed lighting clips
I am replacing recessed lighting but the housing is right next to two beams so the clips on two sides can not lock. Any suggestions?
chefde is offline   Reply With Quote
Old 08-05-2012, 02:45 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
I honestly do not understand.
Speedy Petey is online now   Reply With Quote
Old 08-05-2012, 03:18 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Im going to need a picture on this one as well...
Old 08-05-2012, 06:57 PM   #4
Rewards Points: 1,646
housing is too close to a floor joist to get the clip to engage; I'd throw a screw into the joist through the clip slot IMO.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
k_buz (08-05-2012)
Old 08-05-2012, 07:03 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That is exactly what I do.
Old 08-06-2012, 11:06 AM   #6
Licensed electrician
Rewards Points: 1,754
Sometimes you can rotate the housings so the clips will fit.
Old 08-06-2012, 11:12 AM   #7
I get it now.
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 11:23 AM
Recessed Lighting Layout - HELP foxwoods321 Electrical 12 02-24-2011 09:32 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
