Recessed Lighting Cans - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 10:06 PM   #1
Recessed lighting cans
I want to include some IC rated ceiling fixtures (probably 5 inch or maybe 4 inch) for my electrical upgrade. Is there any problem using new construction cans in a remodel if I have attic access or would I be better using old work cans. Also, since the cans will be rated for insulation contact would it matter if the insulation were foam? Wouldn't the foam make them effectively air tight? Thanks as always
Mike in Arkansas is offline   Reply With Quote
Old 01-28-2010, 06:06 AM   #2
I prefer to use air tight cans, anyhow, either remodel or new construction fixtures. Not sure about foam.
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed lighting & ceiling fan installation advice SillySally Electrical 5 08-05-2009 10:07 PM
Recessed Cans for Outdoor Lighting, Spacing jamiedolan Electrical 7 04-13-2009 04:18 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
