Recessed Lighting In The Bathroom. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2010, 12:20 PM   #1
Rewards Points: 204
Recessed lighting in the bathroom.
I was wondering if you have to put a special kind of can light in the bathroom or can I just use the kind I am using for my whole basement? The light isn't going to be in the actual shower. Here is the light
Also, Why are some crazy expensive and some (like this one) $5-6 apiece?
Thanks.
Abs777 is offline   Reply With Quote
Old 03-11-2010, 12:28 PM   #2
I'm installing 2 recessed over the sink
I'm also installing one in the shower, special trim is required for shower
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Abs777 (03-11-2010)
Old 03-11-2010, 12:29 PM   #3
Master Electrician
Rewards Points: 3,870
Thanks.
They can be in the shower if you use shower trims otherwise no problem throughout the rest of te bath.
Different brands, different quality, smaller sizes usually cost more, low voltage cost even more.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Abs777 (03-11-2010)
Old 03-11-2010, 12:33 PM   #4
Rewards Points: 204
Thanks Guys!
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
Bathroom Recessed Lighting Pineapple Electrical 6 03-03-2008 07:51 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
