Recessed Lighting In Bath. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 03:34 PM   #1
Recessed lighting in bath.
I'm doing a minor remodel on my master bath...new floor tile, paint, nothing major. One of the things I want to change out is the recessed light above the master bath. The fixture currently has a very ugly shower rated trim/lens on it, and I'd like to replace it with a gimbal light to provide more directed illumination. The slope on the ceiling currently directs the light out into the center of the room, and I want it to light the tub directly below it.
The tub itself has no shower, and the ceiling above it is 9 foot and vaulted (the location of the fixture is 9'6" off the floor). The bath is largeish (9'x16') and well ventilated, and the seperate shower unit is 7 feet away and isolated by a glass wall.
At that height and with no shower, the odds of the fixture coming into direct contact with any water is extremely slight. I've been unable to find any gimbal or eyeball 6" wet-area rated lighting trims that will allow me to direct the light while sealing against moisture (and was told by two companies that they don't exist), so I apparently have to choose one or the other.
So I guess I really have two questions: A) Does code require above-bath lighting to be sealed at that height? B) If it doesn't, is putting an unsealed light in that spot a bad idea?
Arthas is offline   Reply With Quote
Old 07-04-2012, 04:13 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Code requires a wet location trim only when subject to shower spray, so unless you have a shower head facing the ceiling, you are fine with an open baffle.
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
Recessed Lighting Job in Shower braves22 Electrical 4 12-19-2011 02:19 PM
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 11:23 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
