Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 10:09 AM   #1
Recessed Lighting
My husband installed the Utilitech recessed lighting (290214) and bought the white shower trim (290205) and we have tried to put the two together but can't seem to figure out how to do it. Does the little dome thing hook on to the metal plate inside of the recessed light or what? For such a simple thing, we are a little slow at putting it together.
srpeters is offline   Reply With Quote
Old 03-26-2011, 11:02 AM   #2
Rewards Points: 1,596
See if this helps:
http://www.cooperlighting.com/specfi...des/698163.PDF
Usually, the trim ring has some thin, springy metal wires with hooks on the ends. These slide into/along a ridge/opening inside the can on the sides. Place one side then the other, then gently push the ring up to the ceiling; it should stay put.
bob22 is offline   Reply With Quote
Recessed Lighting Layout - HELP foxwoods321 Electrical 12 02-24-2011 09:32 PM
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 11:53 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
