Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 11:15 AM   #1
Recessed lighting
I want to wire four recessed ceiling lights I need a wiring diaghram.
bigpete is offline   Reply With Quote
Old 05-31-2009, 11:23 AM   #2
run 14/2 with ground to the closest light, then run 14/2 with ground between each light.
bkeech is offline   Reply With Quote
Old 05-31-2009, 11:25 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
From the switch: black to black, white to white, grounds to grounds.
If the switch is existing use whatever size wire is existing. If it is #12, use #12. If #14 use #14.
Old 05-31-2009, 07:20 PM   #4
Power source======switch box=====light====light====light=====light
====== is two wire cable two wire cable w/ground, sized the same as the circuit you are tapping into.
At sw box, white to white, both blacks to switch.
At lights, color to color.
Use a plastic sw box, leave a ground pigtail for the switch.
Use a metal sw box, use a ground screw in the tapped hole and ground the box.
220/221 is offline   Reply With Quote
Insulating IC recessed lighting. topher0524 General DIY Discussions 4 02-10-2009 06:03 AM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
