Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2008, 02:01 PM   #1
recessed lighting
Can I wire recessed lighting to a switched recepticle or do I have to wire it to the switch?
Bobo11 is offline   Reply With Quote
Old 02-15-2008, 03:11 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Normally go to the wall switch but before you do that check the number of connection at the wall switch [ it possiblty you got a switch loop running to the repectale]
if so you have two choice change the repectale to hot all the time and use the switch to turn on or off the can luminiares or wired driect to the switched repectale [ i am not too crazy due the box size that will get ya hard ]
let us know which way you want to go.
once you decided which way you want to do.
one of us can provide a drawing to get the idea how to hook up properly.
Merci, Marc
Old 02-15-2008, 05:32 PM   #3
........yes
220/221 is offline   Reply With Quote
Old 02-15-2008, 09:20 PM   #4
hms
Remodeling contractor
yes, there is nothing against wiring to a switched receptacle.
hms is offline   Reply With Quote
Old 02-15-2008, 10:29 PM   #5
Union Electrician
goose134's Avatar
But there is something against dimming the receptacle. Just something to think about.
goose134 is offline   Reply With Quote
Old 02-16-2008, 01:10 PM   #6
True.
Typically though you would eliminate the switched recep.
Old 02-16-2008, 01:55 PM   #7
Union Electrician
goose134's Avatar
Agreed. I wasn't sure if it was staying or not.
older recessed lighting issue kibosh Electrical 3 01-13-2008 03:15 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
recessed lighting automation cesar333 Electrical 3 12-28-2005 08:54 AM
