Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 11:20 PM   #1
recessed lighting
i'm putting in some recessed lighting on a sloped ceiling (not sure of pitch i have to check it)
at what slope do i need a sloped can housing?
i'm putting fan in middle of room and 8 recessed lights around it. i'm just wondering will it light up ok or will the slight angle not look right?
room size is 16x25
Kansas is offline   Reply With Quote
Old 01-12-2013, 11:28 PM   #2
" Euro " electrician
frenchelectrican's Avatar
room size is 16x25
The most common methold I know useally eyeball trim useally do the trick however there is a shallow recessed trim which it can offset some way.
But there is one major gotcha if you useing recessced slope ceiling luminaires you will need a bit of room due the houseing is pretty large to comperised the difference on the pitch.
Anything useally over 4:12 you will have to be little more carefull with setting of recessed cans and type of lamps you plan to use that will affect a bit.
Merci,
Marc
Old 01-13-2013, 12:13 AM   #3
Merci,
Marc
Yeah my wife doesn't like the eye ball ones. And I think the rafters are 10 inch so the larger housing will fit. I'll measure pitch tommorrow. Hope it's less than 4/12 would rather just put flush ones up. Thanks for input!
Old 01-13-2013, 11:57 AM   #4
I measure 12.5inch drop over 48 inch horizontal, that's a 3.84 slope I think. Am I going to be ok with flush or should I look for sloped can that works for 2-6 slopes?
Old 01-13-2013, 12:25 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,456
Nothing wrong with them at an angle....my in-laws have a bunch of cans in their vaulted ceiling....all flush mount....not an issue.
ddawg16 is online now   Reply With Quote
Old 01-13-2013, 12:36 PM   #6
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Go online and check out Halo H247ICAT or H47ICAT recess lights. They have a 2 1/2 to 6 1/2 pitch adjustment.
HIVOLT is offline   Reply With Quote
The Following User Says Thank You to HIVOLT For This Useful Post:
frenchelectrican (01-13-2013)
Old 01-13-2013, 12:58 PM   #7
I'll check that out, so far my biggest prob is that I don't see brown trim offered which is what I need
Old 01-13-2013, 02:36 PM   #8
TTW
TTW's Avatar
They sell brown spray paint.......
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
The Following User Says Thank You to TTW For This Useful Post:
HIVOLT (01-13-2013)
Old 01-13-2013, 02:50 PM   #9
Brown? Check out the black trim sometime they will look good as well.
Merci,
Marc
Old 01-13-2013, 03:29 PM   #10
Merci,
Marc
I will look for black as well, the ceiling will be cedar that gets a stain so black might still work.
Old 01-13-2013, 03:30 PM   #11
Very true but just the housing is 3x the cost and the trim as well, would not like to paint it if I'm spending that much more, but its a last resort for sure.
The Following User Says Thank You to Kansas For This Useful Post:
TTW (01-13-2013)
Old 01-13-2013, 05:18 PM   #12
Electrical Contractor
kbsparky's Avatar
IF you want the lights to shine straight down, then you may need a sloped ceiling can and trim.
If you don't mind the lights shining perpendicular to the slope of the ceiling, then you can use the cheap down lights.
-KB
Old 01-13-2013, 06:39 PM   #13
I will expand Kbsparky's comment with that set up., There is one thing you will have to keep it in your mind when you used this type of recessed luminarie the best bulb it will work genrally BR or R bulbs ( either indentscent ou compat flourscent bulb but LED will work good as well but make sure they are rated to work in recessed luminaires )
For the sloped ceilings trims normally I used baffled verison they are pretty good with it unless you want to spread the light around little more then get one with reflective surface to spread out the light more.
But there one thing you will have to keep in your mind if you going to use the dimmer watch the wattage rating. I always go by max wattage of the luminarie / trim it will be used.
Merci,
Marc
Old 01-13-2013, 08:58 PM   #14
Resi EC
Rewards Points: 252
I have done a few homes like this, lights up the room nicely.
With a fan in the peak, you don't want the recess cans too high in the vault, strobe effect can happen.
Gac66610 is offline   Reply With Quote
Help with Replacing Recessed Lighting from the 80's scubakathy84 Electrical 2 11-03-2012 04:57 PM
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
Recessed Lighting Layout - HELP foxwoods321 Electrical 12 02-24-2011 09:32 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
