Recessed Lighting For 15 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 11:56 PM   #1
Recessed lighting for 15 amp circuit
Couple of questions how many recessed lights would I need for my basement which is about 11x24 I was planning on using 6 recessed lights with 100 watt bulbs. Is that enough or is there some formula to determine the correct amount? Also how many recessed lights can I put on a single dimmer switch to a 15 amp breaker? Is it okay to use 14/2 for recessed lights?
thanks
jacads is offline   Reply With Quote
Old 03-12-2009, 01:55 AM   #2
I would be leaning towards 10 cans myself - 2 rows of 5. Make sure the cans will take 100 watt bulbs though, thats pretty hot, as in heat, not Paris Hilton. Look for a can and trim that will take a BR30 65watt bulb, looks better. Dimmers are rated for wattage - bulb watts x quantity. A 1000 watt dimmer would be good for 10 - 65watt bulbs. You need to reduce wattage capability of the dimmer if it is in the same box as other switches. See instructions of the particular dimmer. Also 14-2 is good.
Have fun.
unclduey is offline   Reply With Quote
Old 03-12-2009, 08:30 AM   #3
Most dimmers support a max of 600 watts with no "tabs" removed. This doesn't mean you should fit 600 watts of lighting on one! I would go for 2 dimmers and split it 300-300 watts. Or just pick up a 1000 watt dimmer...
rgsgww is offline   Reply With Quote
Old 03-12-2009, 11:38 AM   #4
Do you have a suggestion as to what particular lights I should use? I have about 9" of clearance with the floor joist and about 14" in between each floor joist. I do not plan on utilizing any insulation around the lights.
Old 03-12-2009, 12:07 PM   #5
Your local home improvement store should have Halo H7 or Juno IC 22. For example: http://www.cooperlighting.com/specfi...nfopdf/H7T.pdf
Old 03-12-2009, 01:12 PM   #6
sweaty
Rewards Points: 276
Use CFL's and you can get as bright as you want, save electricity, and be cooler in the summer.
sweaty is offline   Reply With Quote
lighting circuit design question amakarevic Electrical 15 10-31-2008 03:11 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
Recessed Lighting - How many per 20amp circuit dcd22 Electrical 10 08-27-2007 06:36 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
