Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 03:53 PM   #1
Recessed lighting
Can you install 6 recessed light off of one circuit by starting at a switch that is designed to turn an outlet on and off for a lamp that sits on a table. i've determined all of the outlets in one room are on the same circuit. The max wattage that will be used in that room if all recessed lights and TV etc are on would be approx. 1,500. the electrical wire in place is 14 g.
maretapeacock is offline   Reply With Quote
Old 04-22-2012, 04:05 PM   #2
1500 watts divided by 120 volts equals 12.5 amps.
So assuming that 14 ga wire is on 15 amp breaker your good to go
jammin06 is offline   Reply With Quote
Old 04-22-2012, 04:40 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Depends on how it is wired.
Many times a switch loop is used, so the only way to do it would be to change it so the receptacle is always one to give you a feed at the switch.
Old 04-23-2012, 11:26 AM   #4
Just a DIY guy
Are all modern wall switches 15 amp minimum?
I know some dimmers are limited to 600W, but higher wattage dimmers are available.
M3 Pete is offline   Reply With Quote
Old 04-23-2012, 01:22 PM   #5
Yes...
The Following User Says Thank You to Speedy Petey For This Useful Post:
M3 Pete (04-23-2012)
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 11:23 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
