Recessed Light Trim Not Flush - Tips? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 09:20 AM   #1
Recessed Light Trim not flush - tips?
I have several Halo H3 recessed fixtures that have trims that set into the can with 3 friction tabs. The problem I have is that the can itself gives slightly when the trim is pressed into place, and then the trim won't sit flush-snug with the ceiling. I get a small gap that is visible.
Anyone have a tip or trick to get these trims tight to the ceiling?
sctazmon is offline   Reply With Quote
Old 10-10-2010, 09:31 AM   #2
You might try a thin piece of self sticking weather strip under the lip of the can to block the light
ElectricianJeff is offline   Reply With Quote
The Following User Says Thank You to ElectricianJeff For This Useful Post:
sctazmon (10-10-2010)
Old 10-10-2010, 12:07 PM   #3
Rewards Points: 1,514
Is the ceiling itself not quite flat (coplanar)?
Will the can itself push back into the former position and stay?
Usually the trim piece has a little give to it but the can has to stay in position and exert some force on the trim piece. Could you adjust some screws and make the can sit a fraction of an inch higher in the ceiling?
Old 10-10-2010, 01:12 PM   #4
Licensed electrician
Rewards Points: 1,622
You might try holding the fixture housing down while you push the trim upward.
Old 10-10-2010, 04:04 PM   #5
I wish I could, but the fixtures are rocked in and there is no way to hold them in a vaulted cieling.
Old 10-10-2010, 05:51 PM   #6
Master Electrician
Rewards Points: 3,870
Twisting the trim while pushing up sometimes works for me.
brric is online now   Reply With Quote
Old 10-10-2010, 06:05 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
first thing:
make sure there are no bits of paper hanging below the ceiling. Often times, when cutting the rock, it leaves a rough edge. Then, when painting, it adds to that rough edge and it often leaves material hanging down that prevents the trims from setting flush.
Then, what often works for me is a quick tap or rap on the trims after getting them seated as far as they will go. Do not hit them hard enough or in a way to damage them. This quick rap often causes the retention clips to grab far enough down, due to the rock giving a bit, to keep the trims tight against the ceiling.
Old 10-10-2010, 06:05 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Even with valuted ceilings I have no issue to install the trim rings on the little tip is make sure you pull back the recessed luminaire a little bit by time you put the trim ring on it will close up the gap a bit.
Did you have correct slope rating trim ring ? { there are few diffrent slope rating on them so watch out on that }
Merci.
Marc
Old 10-11-2010, 08:20 AM   #9
Thanks for all the suggestions.
I figured it out. Out of the box, the trims took a lot of force to push in and in turn it pushed up the can slightly and prevented a flush fit when the can settled back down.
I simply bent back the retention tabs a bit such that I didn't have to use as much force to push in the trims. Now the trims sit flush.
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 06:00 PM
Recessed Shower Light Ptron Electrical 3 10-05-2010 05:41 PM
Recessed light trim Joel Kramer Electrical 1 08-05-2010 08:44 PM
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 04:30 PM
choosing right bulb and trim kit combo for recessed windowguy Electrical 3 11-29-2009 03:17 PM
