Recessed Light Trim Not Compatible - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 02:38 AM   #1
Recessed light trim not compatible
Hi,
I have some recessed lighting in my kitchen that I wanted to add some style to. The lights I have were installed when the house was built. They are 6" generic cans. They are the kind that has the E37 bulb connector directly connected to the baffle/trim of the light.
I was thinking of adding a similar product as this
http://www.lowes.com/pd_290211-95029...bay&facetInfo=
However, since the bulb's socket is permanently attached to the trim it doesn't seem to fit. Does anyone have any suggestions on how I might modify this to make the trim fit? Or maybe you can show me some trim that would be compatible with my cans.
The only thing I can think of is to cut the baffle in half then drill holes in the can to hold the springs for the new trim.
Or, install a new bulb socket/plate from a compatible can that the trim can attach to.
Hopefully I'm being clear in my description. Thank you for your help.
Recessed light trim not compatible-img_20110910_033159.jpg   Recessed light trim not compatible-img_20110910_033308.jpg
S11D336B is offline   Reply With Quote
Old 09-10-2011, 05:26 AM   #2
DIY staff
Rewards Points: 7,174
That can has had the socket plate removed----Look at a can in the store and you will see that there is an adjustable plate (round with a hole for the socket to snap into--side arm with slots for wing nuts and screws.)
Don't know where you could get the brackets---Any electrician has trashed dozens or hundreds of them--as some trims don't use the things.
Google images will get you a picture of the missing part----Mike----
Old 09-10-2011, 06:09 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Just take your old trim out and bring it in to the store. Try and match it up physically but with a nicer style.
Old 09-10-2011, 07:21 AM   #4
Master Electrician
Rewards Points: 3,964
Looks like it has torsion springs to me.
brric is online now   Reply With Quote
Old 09-10-2011, 07:34 AM   #5
DIY staff
I think Speedy has the best idea---Pop the socket out of that old trim and buy one of the same type.
Plenty of fancy designs in the socket mount type.
Old 09-10-2011, 07:42 AM   #6
Licensed electrician
Rewards Points: 1,876
Looks like a Progress fixture. You should be able to find a label inside that has the model number on it.
To remove you just squeeze the two black tabs above the trim.
Old 09-11-2011, 12:17 AM   #7
Thanks for all the reply's. You guys are awesome!
I looked again at the light and was able to get the baffle off of the light bulb socket. It just clipped out.
Does anyone know where I can get some of these kinds of replacement trims in different colors? I looked on homedepot, but they don't show pictures of the whole trim just what you would see when the trim is installed.
Does anyone have a link for these types of trim?
I looked for a label on my cans, but the builder sprayed popcorn ceiling material all inside the cans. If there is a label, it's not visible.
Old 09-11-2011, 05:04 AM   #8
DIY staff
I know Depot and Menards carry a selection of trims like that---
Old 09-11-2011, 08:13 AM   #9
Most trims are going to be in white to be less obtrusive on the ceiling. Other colors would make the ceiling look like swiss cheese.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Hot air blown out of recessed light penetration deerhunter HVAC 5 10-31-2010 10:54 AM
Recessed Light Trim not flush - tips? sctazmon Electrical 8 10-11-2010 08:20 AM
Recessed Shower Light Ptron Electrical 3 10-05-2010 05:41 PM
Recessed Light Install Question kennykenny Electrical 2 12-03-2008 10:00 AM
