Recessed Light Removal Help - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2012, 08:20 PM   #1
Rewards Points: 31
I need to temporarily remove some recessed light cans to gain access for running low voltage wire in the ceiling. Can anyone give me advice on removing the can by looking at the picture?
These lights were retrofitted by the previous owner, so I'm pretty sure they are not nailed to rafters. A second floor is above, not an attic. I suspect the black clips are holding it in, but I don't know how to unclip them. I've pushed them up, down, in, out, etc.
Any help would be appreciated.
lkstaack is offline   Reply With Quote
Old 12-10-2012, 08:42 PM   #2
DIY staff
Rewards Points: 7,174
Those black things are springs that curve down and press against the drywall---stick a flat screw driver into the slot at the top and push up a bit and they should release---
goodle the instructions of a Halo recessed light---that's not a Halo but the springs are similar
Old 12-10-2012, 10:59 PM   #3
You might want to run a razor knife around the edge of the can too. It looks like they painted right over the light and when you take it down it will probably peel large sections of paint off of the ceiling.
AlKapone is offline   Reply With Quote
Recessed Can light making noise Kenny101 Electrical 6 02-27-2012 11:25 PM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 12:21 AM
Recessed light junction box question chris_k Electrical 1 04-21-2009 08:12 AM
Recessed Light Question harleysilo Electrical 8 01-27-2009 06:58 AM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
