Recessed Light Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 01:04 PM   #1
Rewards Points: 150
Hi, I'm wondering if recessed light can be mounted into wood (versus typical ceiling drywall). I have a closet that recently had to be redesigned. The doorway header is a 2x10 covered with a 3/4 pine board. I'm considering mounting a recessed light in the header. There is approximately 6" of air space above the 2x10.
Since someone will most likely want to know the wall the closet is in was moved out (away from back of closet) by 6" or so, thus the header needed to be increased in width, so the doors could be mounted further from the back of the closet, so a new washer dryer would fit in the closet. I can post some pics if that helps.
harleysilo is offline   Reply With Quote
Old 01-22-2009, 09:53 PM   #2
Electrician
ctsmiths's Avatar
Rewards Points: 150
Pics are good if you have them.
ctsmiths is offline   Reply With Quote
Old 01-22-2009, 11:14 PM   #3
Yes, just make sure you get Type IC (Insulation Contact) recessed fixtures. Type IC is rated to be in direct contact with combustible materials.
Sliver is offline   Reply With Quote
Old 01-23-2009, 10:39 AM   #4
Rewards Points: 150
Sweet, thanks and that makes good sense.
Old 01-23-2009, 10:44 AM   #5
Rewards Points: 150
Old 01-26-2009, 04:04 PM   #6
Rewards Points: 150
The space available to mount a recessed light, including some space behind the current pull string light.
Old 01-26-2009, 09:03 PM   #7
Looks like you can squeeze a 4" can in there.
Instructions will say "Do not install in such a manner as to entrap heat" whatever that means. Maybe screw a vent cover over the hole on the backside.
An IC can will have a little overheat switch built in it.
220/221 is offline   Reply With Quote
Old 01-26-2009, 09:09 PM   #8
I buy cans now that I can use a CFL bulb
Eliminates the heat issue
Old 01-27-2009, 07:58 AM   #9
Rewards Points: 150
Both good ideas, thanks.
Recessed Light Install Question kennykenny Electrical 2 12-03-2008 11:00 AM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 07:53 PM
Halogen recessed light question tripower Electrical 14 10-12-2008 10:34 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 10:25 PM
