Recessed Light & Plumbing - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 09:12 PM   #1
Is there a minimum distance requirement between recessed light and plumbing? My plumbing is copper and black pipe.
Thank you for your help.
MartinD is offline   Reply With Quote
Old 09-29-2010, 09:54 PM   #2
Just call me Andrew
Rewards Points: 1,020
I would think anything more than a couple inches is OK. I just redid my bathroom, and I had a PVC drain pipe a little too close for comfort to the top of my halogen recessed fixture in the shower, especially with the shower trim trapping all that heat.
What I did was wrap the PVC pipe with heat-resistant tape. I got this tape from the auto parts store:
http://www.napaonline.com/Search/Det...081_0282514673
I just cut it into strips and wrapped it around the pipe. I'm not sure how the adhesive would react with the copper and black pipe though.
14.69 Each
Features & Benefits
Aluminized Heat Barrier Is Made Of Woven Silica w/ Flexible Aluminized Finish, Highly-Reflective Surface Of Material Is Capable Of Withstanding Temperatures In Excess Of 2,000 Deg F; Use On Stardard Rivets w/ Backup Washer Or Weater Strip Adhesive; 12" x 12"
Andrew
secutanudu is offline   Reply With Quote
Old 09-29-2010, 10:47 PM   #3
" Euro " electrician
frenchelectrican's Avatar
As long it is not plastic pipes you are ok with minum distance but if you going to replace the steel or copper pipes with plastic then you will need few inches away from the recessed luminaire unit.
Merci.
Marc
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 09:29 AM
Recessed light junction box question chris_k Electrical 1 04-21-2009 08:12 AM
Recessed Light Question harleysilo Electrical 8 01-27-2009 06:58 AM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 06:53 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
