Recessed Light Placement - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2010, 09:09 AM   #1
I want to put recessed lights in two bedrooms with a fireplace. The problem is that the fireplaces are off center on the wall. I want to accent the fireplaces with fish eye lights and have a couple of regular lights to light the bare spots. I also want a ceiling fan in the middle.
Here are the designs I came up with. I think the fireplace fish eyes are in the right spot because I pumped through some trig to make the fisheyes point down at 30 degrees to the fireplace mantel. However, the other lights are way off center because of it.
I want to wire the fisheyes on one dimmer, the regular recessed lights on another dimmer, and the ceiling fan on two regular switches.
Another question. Are 6" fisheyes too big? I seenthey make 5" and 4".
Any ideas would be appreciated. Thanks.
jonathan03 is offline   Reply With Quote
Old 04-04-2010, 09:23 AM   #2
Master Electrician
Rewards Points: 3,874
I would suggest your first layout, aligning the lower right can with the lower left can then adding two cans centered on the fireplace perhaps on a separate switch making the use of future dimmers more convenient. Moving the fan so it is cetnered left to right between the long wall and the fireplace seems better to me as well.
brric is online now   Reply With Quote
Old 04-04-2010, 09:35 AM   #3
Licensed electrician
Rewards Points: 1,626
I like bedroom 1, except if I were doing it I would use 4 6" instead of the 2. I would also pull the eyeballs in more to the centerline of the FP, instead of being out to the sides.
You definitely do not want any recessed light above the fan blades unless you like the strobe effect.
Old 04-04-2010, 10:26 AM   #4
Thanks for the advice. You suggest having two more 6" regular recessed lights that aren't eyeballs?
I should point out that Bedroom 1 and Bedroom 2 are two different rooms. Not different configurations for the same room. I have a large Victorian house with 4 fireplaces. This is just half the work ;-) Two more rooms after this trial is done.
Old 04-04-2010, 10:40 AM   #5
Master Electrician
I like 4" cans myself but they are generally more costly and give less light.
Old 04-04-2010, 11:25 AM   #6
Yes, i was suggesting 4 6" in the corners. I think this would be more balanced than just 2.
Old 04-04-2010, 12:33 PM   #7
Master Electrician
it would cost a fair bit more but what if you were to put 4 4" in the corners? this combined with the ceiling fan(assuming there's a light on it) would give ample light in a room that size if it was so needed and use smaller accent lighting above the fireplace. This would allow you to have the main lights off and just the much dimmer "mood lighting" on when you've got a nice cozy fire going.
andrew79 is offline   Reply With Quote
Can I use recessed light wiring for a regualr light? integrity634 Electrical 1 03-18-2009 06:29 PM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 06:53 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 07:32 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
recessed light farrington135 Electrical 3 12-03-2006 12:02 PM
