Recessed Light Near Csst Gas Line? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 07:19 PM   #1
Recessed light near csst gas line?
I am installing IC recessed lights in my basement and the location of one of the lights is in the same bay as a csst gas line. I would say that there should be a good 5-6 of clearance between the gas line and the actual can, is this a problem? I have searched this site and many others and am unable to find a relatively good answer. I wouldn't think it would be a problem because the clearance between the can and insulation can be as low as 1 inch. At the moment there is no fire rated insulation in the bay, there is insulation (which is another question) by not fire rated. Thanks in advance for all responses.
sasutto1 is offline   Reply With Quote
The Following User Says Thank You to sasutto1 For This Useful Post:
9erdax (07-26-2011)
Replacing a chandelier with a recessed light. RyanD General DIY Discussions 5 01-19-2016 10:27 PM
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 09:29 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed light sound transmission? jogr Electrical 2 03-12-2009 06:42 PM
Recessed light wire size jizzle Electrical 6 12-03-2008 09:56 AM
