Old 06-18-2007, 02:46 PM   #1
Question
Recessed light near air duct
I am in the process of installing Recessed lighting Remodeling Cans - Non-Insulated Ceiling of my living room. I have made the holes in the cieling but the final hole happens to be on the side of an air duct. If I install the can, it is definetly touching the duct.
Does this present a fire hazard being side by side?
Geo747 is offline   Reply With Quote
Old 06-18-2007, 05:01 PM   #2
I would put those proper type of insulation material between the heated air pipe and the canned light to avoid direct contact... then go from there... figure out the proper type of installation may requires some knowledge here...I don't know if those type where you use to insulate water pipe is good enough as it needs to stand the heat from the canned light...
not doing so will probably don't create dangerous except you wil waste air conditioning in the summer... when the can is turned on... but then if you use those low power light bulb... it is going to be little issue....
KUIPORNG is offline   Reply With Quote
Old 06-19-2007, 04:51 PM   #3
Master Electrician
JohnJ0906's Avatar
Is the duct metal? If so, there should be no problem. If it is plastic duct, or insulated, you need some space.
Are the recess cans IC rated?
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 06-19-2007, 06:41 PM   #4
They also sell shallow lights. You may be able to replace that one fixture with a shallow model.
send_it_all is offline   Reply With Quote
Old 06-20-2007, 02:12 AM   #5
There is no insulation in the area so I bought the non-IC cans. The duct has a foil type material on the outside and is insulated.
Is there something I can buy to put between the can and duct...for example a metal sheet or some sheetrock?
Old 06-20-2007, 09:16 AM   #6
Licensed Pro
Replace that can with one that is IC rated. That is the easiest and safest solution.
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-15-2007 12:08 AM
recessed light farrington135 Electrical 3 12-03-2006 01:02 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Recessed Outdoor light fixture Scott_K Electrical 6 04-05-2005 05:53 PM
