Recessed Light Mounting Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2008, 02:13 AM   #1
Question
Hello.
I'm in the process of finishing my basement. I want to install recessed lighting into the main floor TJI that are 12" deep and 16" o/c non-insulated new construction and I want to use the 6" dia. ones.
From what I have found at Rona and Homedepot you can either get the large box kits that I guess are more for insulated ceilings or something like this:
My question is how do I mount this inside the joist bay? Do I need to buy handle bars for it or what and if so can someone send me a link for it either at Rona.ca or homedepot.ca?
mfleming is offline   Reply With Quote
Old 10-25-2008, 06:47 AM   #2
Electrician
Originally Posted by mfleming View Post
Hello.
The light in the picture is an "old work" style can, which means it was intended to be installed after the finshed ceiling, Just look for a new work style light. I would stick with a name brand also like Halo, Juno, Lightolier, to name a few. Halo being the least inexpensive.
chris75 is offline   Reply With Quote
Old 10-25-2008, 06:52 AM   #3
Rewards Points: 338
mfleming, here is a link to what you'll need (or similar)
http://www.rona.ca/shop/~recessed-li...ectricity_shop
petey_c is offline   Reply With Quote
Old 10-25-2008, 07:40 AM   #4
They do have brackets that attach to both sides of the fixture and telescope to the ceiling joices . The ones I installed came with the fixture . In my opinion , surface mount fixtures would be more efficient .
electro is offline   Reply With Quote
Old 10-25-2008, 12:38 PM   #5
Electrician
efficient to what?
Old 10-25-2008, 10:08 PM   #6
DIY'r
ScottR's Avatar
Remodel/old-work cans aren't necessarily a bad idea in new construction b/c you can tweak the final location based on the finished space (providing your wire drops are close enough).
ScottR is offline   Reply With Quote
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 09:25 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 07:32 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
recessed light farrington135 Electrical 3 12-03-2006 12:02 PM
Recessed Outdoor light fixture Scott_K Electrical 6 04-05-2005 04:53 PM
