Recessed Light Issue - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 09:53 PM   #16
Licensed electrician
Rewards Points: 1,478
It does not matter that the wiring goes out in two directions from the one fixture. The integrity of the connections does matter.
Old 08-26-2012, 10:04 PM   #17
Would you mind elaborating? Which connection do you think may be wrong?
PS - If I'm not put on hurricane duty tomorrow at work, I'll be going to get a voltage tester and figuring out if the cable providing power isn't providing enough...
Just tried traditional incandescent bulbs and not getting anything out of them at all...
Come by and visit our renovation 'blog': '59ish Brick Ranch: Updating... everything...
natedro is offline   Reply With Quote
Old 08-26-2012, 11:03 PM   #18
Sparky
Rewards Points: 510
you need a standard voltage tester (even a simple light tester would work), and check between the black and white of your 'power cable' in the switch box.
Techy is offline   Reply With Quote
Old 08-26-2012, 11:29 PM   #19
That's the plan for tomorrow when HD is open. Just finished routing the switch cable to a fixture on the end of the group... no difference, not that I was really expecting one... just figured it'd be wise to rule out since that'd be free.
Old 08-26-2012, 11:59 PM   #20
Updated layout of wiring:
Previously wired something like this:
The switch that controlled the fan and the light separately was labeled behind the old switch and worked fine, so I capped the fan since I don't have one now. However, at the old fixture connection, it may have been that the random wire connecting near the other switch box was actually providing power.
I don't know.. this mess is confusing. I'm thinking of calling in a pro just considering all the variables.
Another FYI: none of the neutrals were connected anywhere but at the fan previously. I don't know what that's all about... seems to be a running theme in this old house.
Old 08-27-2012, 06:29 AM   #21
Resi EC
Rewards Points: 252
When you removed the ceiling fan, do you remember if there was a white wire tied to a black wire(in the ceiling box)?
Gac66610 is offline   Reply With Quote
Old 08-27-2012, 09:57 AM   #22
I don't remember unfortunately. When I unscrewed the ceiling cover, the old fan fell and the wire nuts and wires separated. There was no ceiling box... the wire was running straight to the fixture from the attic.
The ceiling fixtures in this house have all been hacked up. Slowly changing them all and installing light boxes. There are none except for the ones I've added currently.
Old 08-27-2012, 10:28 AM   #23
Would you mind elaborating what that would change? I can't think of what else to try other than getting a multimeter and testing the current "power" in.
Old 08-27-2012, 11:10 AM   #24
A white spliced to a black would typically indicate a switch loop. The white in that case is not a neutral.
Old 08-27-2012, 12:20 PM   #25
Resi EC
Rewards Points: 252
Thanks Jim,(I was at work)
Yes, Jim explained it well. If you are not sure about that, do you remember how many wires were at the fan, just black and white or were there several blacks and whites?
There are several ways to wire a three way circuit, all I'm trying to do is figure which way yours is. So I'm sorry for being vague right now, the more we can learn from what you have/had the easier it is to help.
Old 09-22-2012, 02:51 PM   #26
Sorry for the delay but just getting back to this.
So, I bought a tester. Lo and behold, my "power" cable is only giving a volt or so... "phantom voltage" or whatever people call it. So, somewhere at the ceiling fan before, power was being provided to the switch from the fan. None of the 3 wires currently at the switch have power. I'm starting to think this was the most hacked fixture in the house.
The old cable that connected at the fan and no loner is a part of this recessed circuit was going to provide the power for the pendant lights, however somehow that also isn't getting any power according to my tester. There must be some weird wiring behind my walls in this room. Any advice??? Any ideas of how to remedy this? New branch? Lol...
Old 09-23-2012, 04:34 PM   #27
Solved. I have no idea how the old light worked, but all my recessed lights work now. I even got the pendants powered. Finally.
Sent from my Samsung Galaxy S2 using DIY Chatroom's App
Replacing a chandelier with a recessed light. RyanD General DIY Discussions 5 01-19-2016 10:27 PM
Recessed Shower Light Ptron Electrical 3 10-05-2010 05:41 PM
Recessed light suggestions? vyjeff Electrical 1 04-27-2010 01:26 AM
Trouble Inserting Recessed Light Into Ceiling Cavity PotLightGirl Electrical 7 11-02-2009 01:15 PM
Recessed light junction box question chris_k Electrical 1 04-21-2009 08:12 AM
