Recessed Light Install Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2008, 10:34 AM   #1
Rewards Points: 664
I am attempting to install a 6" recessed can light in the place of an existing ceiling fixture in my kitchen. I have removed the existing outlet box in the ceiling and am ready to proceed.
My question/problem is that the location of the hole in the ceiling has one edge cut right on the bottom edge of the joist above it. I am ready to cut the bigger hole in the ceiling for the canned light and am concerned about the canned light fitting above, in the ceiling, when when the joist is right on the edge of the hole.
Are my concerns legit or I am just worrying about nothing? I was planning on cutting the new hole with one edge(under the joist) overlapping the exisiting hole. I have attached a picture to hopefully help clarify what I am talking about. Should I cut the hole moving it iin some other direction? Any assistance will help. Thanks!
kennykenny is offline   Reply With Quote
Old 12-03-2008, 10:50 AM   #2
Registered User
Termite's Avatar
You need to skooch that hole over a little in order to be able to install a remodel can. They need some room at the edges to lock onto the sheetrock, and it would be a good idea to get a little clearance from the combustible joist.
Notching the joist to fit the can in should not be considered as an option.
Old 12-03-2008, 11:00 AM   #3
Rewards Points: 664
The hole edge is right on the bottom edge of the joist. If I scoot if over a bit, I am assuming that you mean to move it a little bit away from the hole(more to the right)edge? This will give a bit of wiggle room within the hole when the can is inside of it and the trim ring will cover up this gap?
Installing recessed light trim helpless handyman Electrical 18 07-30-2009 05:35 PM
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 09:35 AM
recessed light farrington135 Electrical 3 12-03-2006 01:02 PM
Recessed Outdoor light fixture Scott_K Electrical 6 04-05-2005 05:53 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
