Recessed Light And Drop Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 02:25 PM   #1
Rewards Points: 640
recessed light and drop ceiling
I am putting recessed can lights in a small drop ceiling. I have a junction box in the ceiling that is metalic, which romex is fed to it from the switch in the wall. The box is tied to ground of course with a ground pigtail
Now, from the metal junction box to the recessed light, should this be armored cable, or do romex and somehow staple it to the joists to keep it from moving too much? the joists are about 9 inches from the top of the ceiling right now.
Also, the lines for lighting are all 12 gauge, do I need to use 12 gauge from the junction to the two can lights? or is 14 gauge alright? I know you aren't supose to change gauge on a circuit generally, but this is an end fixture, not a branch line. Nothing else will feed off it.
This is going to have two to three (max) 75 watt can lights on the switched line.
Thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 03-08-2013, 02:59 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
If the circuit is wired with all #12 and on a 20A breaker then you must use #12.
Using #14 and changing the breaker to a 15A is dumb.
Speedy Petey is online now   Reply With Quote
Old 03-08-2013, 04:09 PM   #3
Rewards Points: 640
That's what I thought, breaker is already 20 amp, all the lines are 12 gauge coming from that breaker
what about the cable type? I assume romex (NM) is allowed if boared and stapled... or should it all be armored (AC) cable?
Old 03-08-2013, 04:32 PM   #4
Licensed electrician
Rewards Points: 1,054
Type NM cable should be fine.
Old 03-08-2013, 04:36 PM   #5
"Using #14 and changing the breaker to a 15A is dumb."
Is this NEC wording?
Hardway is offline   Reply With Quote
Old 03-08-2013, 09:14 PM   #6
Yeah, that was the ROP I was involved in.
The Following User Says Thank You to Speedy Petey For This Useful Post:
jbfan (03-09-2013)
Help!! for installation of a hanging light from a drop ceiling Marilee516 Electrical 3 12-04-2011 03:46 PM
Installing recessed lighting in a new drop ceiling rwood@weg.net Electrical 2 11-30-2011 03:54 PM
Light fixture in a drop ceiling? kosherdill Electrical 1 03-01-2009 01:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Pool Table Light in Drop Ceiling JJdeadhead Electrical 5 04-18-2007 09:01 AM
