Recessed Light Directly Over Shower - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2009, 01:09 PM   #16
Rewards Points: 109
What does "over the tub" mean? right over? 2' away from the edge?
BimmerRacer is offline   Reply With Quote
Old 08-26-2009, 01:10 PM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
What!.. no TV while in the tub!!....oh wait.. you just said no receptacles over the tub....
Even so I wonder how you watch tv while showering...
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-26-2009, 01:15 PM   #18
Rewards Points: 109
I got wall space to move it
Old 08-28-2009, 09:12 PM   #19
If it's recessed & the outlet is in the next room
TV ok? Over Toilet yes, over bath?
Old 08-28-2009, 09:36 PM   #20
Registered User
Termite's Avatar
You can install the receptacle anywhere that isn't immediately above the tub or tub deck. The exact code language escapes me, but as long as it isn't over the tub/tub deck, you're ok. I'd say that if you were to install glass tub walls all the way to the ceiling, that would pretty much identify the no-no zone. The code doesn't say that a switch or receptacle has to be ___ inches away from a tub.
The code doesn't say that the TV itself can't be in that space as I recall. It might raise some eyebrows though, so I'd get it pre-approved with your inspector before you do it.
You might be able to get away with putting the receptacle behind a cabinet door in an adjoining room. BUT, you might get hassled for running the appliance cord inside the wall, a concealed location. In the interest of safety and compromise I've allowed this installation before as long as the receptacle was absolutely accessible only from the adjoining room. I also asked for a GFCI receptacle even though the receptacle wasn't in the bathroom...In the interest of give and take.
Old 08-28-2009, 09:55 PM   #21
Chicago, IL
Michael Thomas's Avatar
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-28-2009, 10:08 PM   #22
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
LOL I was just joking about the TV. But seeing that picture guess I see it would be kind of cool...
Though if seriously putting a TV over a bath I'd actually fix something up so it's inside an enclosed glass cabinet of some sort. "just in case". Definably GFI protect the whole circuit too.
Old 08-28-2009, 10:19 PM   #23
Chicago, IL
The owners manual for every conventional television and monitor sold in the US contains a warning to the effect that:
and the only type of television or monitor you are allowed to use in such locations is a unit specifically designed for installation at such locations.
I've never actually seen one of those except in a catalog, instead I see various sorts of Darwin Award efforts, for example:
Old 08-28-2009, 10:34 PM   #24
Actually I was thinking of the TV in the other room
A niche shelf blocked from the shower/bath by glass
But I can't say that I have ever wanted to watch TV while showering
We have a radio in the bathroom that I play
From the hot tub (outside) we will be able to view the TV in the sunroom
And hear it with the window/slider open
I remember like 20 years ago a friend built their TV into the laudry closet
It freed up a lot of room in the main room
The 1st "flat screen" TV
Owners manual....read.....TV....does not compute
Old 08-29-2009, 05:43 AM   #25
Chicago, IL
Though such disclaimers are very handy to the surviving spouse's lawyer when they sue the builder, the electrician, the real estate agent, and everyone else in sight.....
Old 08-29-2009, 10:39 AM   #26
Wire Chewer
Rewards Points: 126
LOL I don't know what's worse, seeing a TV over the bath, or the fact that there's an outlet, and to make matters worse it's not a GFI outlet!
Old 08-29-2009, 10:47 AM   #27
Could be a GFCI breaker
I don't like an outlet any where near the tub/shower
Heck I don't even like them near the sink
But in a small bathroom - no choice
Old 08-29-2009, 12:20 PM   #28
Chicago, IL
Has to be withing 3 feet of each sink basin:
Old 08-29-2009, 12:29 PM   #29
Has to be withing 3" of each sink basin:
3"
Old 08-29-2009, 01:58 PM   #30
Electrical Contractor
kbsparky's Avatar
....The AFCI code changes are a result of fires started by arcing
Still a lot of discussion going on regarding AFCI's
I believe that the AFCI code changes were a result of extensive lobbying by the Eaton Corporation (manufacturer of Cutler-Hammer). I still have a bad taste in my mouth over how they implemented this requirement.
-KB
Shower light farmerde Electrical 4 01-21-2009 09:12 PM
Installing a recessed light y_wren Electrical 6 11-14-2008 09:47 AM
Replacing hall light fixtures with recessed lights POMEXCAN Electrical 3 04-16-2008 10:40 PM
Recessed Shower Stall Jareb Remodeling 2 06-20-2007 10:28 AM
Recessed Outdoor light fixture Scott_K Electrical 6 04-05-2005 04:53 PM
