Recessed Light Converter? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 07:18 AM   #1
Rewards Points: 552
Recessed light converter?
Does anyone have any experience with this product?
http://www.thecanconverter.com/store/
We're considering purchasing one to convert a recessed light to a hanging table lamp.
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 12-01-2008, 07:25 AM   #2
Haven't heard of it until now. I don't like the part where they say "convert the halo lights to ceiling fans" If you do that...I think we know what would happen.
rgsgww is offline   Reply With Quote
Old 12-01-2008, 07:51 AM   #3
Rewards Points: 2,350
It seems OK if you want to use a light weight fixture. But there is no way I'd hang a large chandelier or ceiling fan from it.
Old 12-01-2008, 09:13 AM   #4
Rewards Points: 552
I agree. We're only going to hang a table lamp, which isn't too heavy.
Old 12-01-2008, 12:10 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
Table Lamp? I am assuming this is meant to be hung over a table like a chandelier? Usually these adaptors are only rated for a max of 25 pounds, I would check to make sure your light fixture doesn't exceed 25 pounds.
theatretch85 is offline   Reply With Quote
Old 12-01-2008, 12:31 PM   #6
handyman mark
can light conversion
If your removing a can light and replace it with a different kind other than another can, you must turn off all power giong to old can then it can be removed from in side there should be clips holding the reflector in place or it may also screw out.
After this the intire assembly MAY be pulled through the ceiling and the wires disconnected, if not you will have to get to it from the attic or crawl space.
The hole it leaves behind maybe small enough to be coverd by the new fixture, if not you will need to patch it or get a decoritive ring for around it.
Now you will have to mount a 4x4 or octaganel box in the area you removed the CAN.
Make shure you mount it securly( I run a 2x4 between the joist and fastin with deck screws) just make shure your box comes out flush with the cieling.
Pull the wires through the box( make shure you use a clap for the wire)
Now you should be ready to mount any light you wish
MARK M. is offline   Reply With Quote
Old 12-01-2008, 12:44 PM   #7
Rewards Points: 506
Mark, look at the Op's first post in this thread, he is looking to use a converter kit to keep the can in place and attach a new fixture over the can.
Old 12-01-2008, 02:36 PM   #8
Registered User
Termite's Avatar
I sure don't like the look of that device at all. I wonder if it has any sort of UL listing/testing or an ICC evaluation?
What if the device is being installed in remodel cans, which are supported by nothing more than sheetrock!?!?! I wouldn't hang a 25 pound fixture from a new work can, let alone a remodel can.
They advertise hanging ceiling fans from it. That is negligent. Fans must be supported by fan boxes, no exceptions.
This has to be one of the worst product ideas (from a safety and sound electrical practice standpoint) that I have seen in a very long time.
Old 12-01-2008, 02:53 PM   #9
I can't imagine what some people have done with remodel cans and this... *big hole in ceiling*
Installing a recessed light y_wren Electrical 6 11-14-2008 09:47 AM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 06:53 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 07:32 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
recessed light farrington135 Electrical 3 12-03-2006 12:02 PM
