Recessed Light Box - No Ground - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 05:55 PM   #16
Rewards Points: 93
based on this recessed ligth adapter, i can wire the ground to the recessed can.
dumbengineer is offline   Reply With Quote
Old 03-10-2013, 03:36 PM   #17
Rewards Points: 93
If light fixture don't have ground, can circuit breaker trip?
If light fixture doesn't have ground or ground came loose or wasn't wired correctly, can circuit breaker still trip in case of overload?
Old 03-10-2013, 03:42 PM   #18
Licensed electrician
Rewards Points: 1,630
The ground is for a short circuit or a fault.
The breaker will trip on overload without a ground.
Old 03-10-2013, 04:39 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Even though the breaker may still trip it still may be VERY dangerous.
WHY are you asking this?
Old 03-10-2013, 08:12 PM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
recessed light box - no ground
This!
Old 03-10-2013, 08:27 PM   #21
So then this thread is a duplicate of the other.
Old 03-10-2013, 08:30 PM   #22
OK, I get it now. He was not liking the answers in the other thread so he started this one hoping for more favorable ones.
Old 03-10-2013, 08:32 PM   #23
That adapter kit is out the window now. You cut the wires, removed the socket and thermal overload.
REMOVE the can, install a fixture box, patch the ceiling and install your track.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (03-10-2013), stickboy1375 (03-10-2013)
Old 03-10-2013, 08:56 PM   #24
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Isn't that the logical thing to do? lol...
Old 03-10-2013, 08:58 PM   #25
jbfan's Avatar
Rewards Points: 490
Not the first time, nor will it be the last!
Old 03-10-2013, 08:59 PM   #26
E2 Electrician
It does seem to be the MO for this type of situation... :-/
Old 03-10-2013, 09:09 PM   #27
Rewards Points: 980
He probably should have asked this IN the other thread, but it wasn't covered there, so he is asking. I didn't read the other thread very carefully, but I expect he can't figure out how to access the ground and wants to make sure the breaker will still work if he blows it off. Not a big deal.
The bigger issue is whether he should be doing electrical work if he has to ask a question like this. There isn't much that is more basic.
Toller is offline   Reply With Quote
Old 03-10-2013, 09:24 PM   #28
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
He wants to tape the ground to the shell of the can.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (03-11-2013)
Old 03-11-2013, 01:02 AM   #29
Rewards Points: 512
but the recessed can is grounded, right? and i can tape the grounding wire of tracklight to the recessed can, right?
i'm not saying that's the proper way but it can be done like that, right?
You can wrap it around a clothes hanger and nail it to the stud, if you want, and you can turn the can upside down if you want.
If you want it to work right, go with the advice you've requested.
My advise is to leave it alone.
Old 03-11-2013, 05:57 AM   #30
It's a bit confusing, but the two threads were merged.
Three romex into recessed light box - light won't turn off coopns Electrical 12 05-04-2012 07:27 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Recessed Shower Light Ptron Electrical 3 10-05-2010 05:41 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 06:53 PM
