Recessed Light Box - No Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 12:49 PM   #1
Rewards Points: 93
recessed light box - no ground
i'm converting my recessed light to install track light.
i dont see any ground wire in my recessed light box though only hot and neutral.
where do i connect the ground wire of my track light?
my house is a new house.
dumbengineer is offline   Reply With Quote
Old 03-08-2013, 01:03 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
The ground wire will be inside the j box on the side of the recessed can.
Old 03-08-2013, 02:04 PM   #3
Rewards Points: 93
so i need to remove the recessed can and look for the junction box and wire the track light ground wire?
can i connect the track light ground wire to anywhere in the recessed can?
or can i just not connect the ground wire of track light?
Old 03-08-2013, 02:20 PM   #4
Rewards Points: 640
pull the three screws on the recessed can dome, that will let you drop the dome out, and behind it is a junction box
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 03-08-2013, 02:33 PM   #5
Rewards Points: 640
I'd also check the gauge of the wire in the can light if you plan on using that as a connection point, the devices are usually designed to handle 75-100 watts at most, they might not even have 14 gauge wires to the sockets... not sure if they ever used smaller gauge wire for that or not
Old 03-08-2013, 03:10 PM   #6
Rewards Points: 93
Can I not wire the ground wire?
Old 03-08-2013, 04:11 PM   #7
Rewards Points: 640
I wouldn't wire a ground to the housing, I'd go straight back to the junction box that is inside the housing... in theory you could tap a screw into the housing since it is grounded... but that is kind of the half assed way of doing this...
Old 03-08-2013, 04:22 PM   #8
Rewards Points: 12,876
Is there an attic above so you can get to the juntion box?
Old 03-08-2013, 04:37 PM   #9
Licensed electrician
Rewards Points: 1,038
You could remove the recessed housing and wire into the track end feed. All the connections will be in one spot.
Old 03-08-2013, 04:56 PM   #10
Rewards Points: 93
so the half-ass way is to tape using electrical tape the ground wire to the recessed can housing. this is ok right.
i'm having a difficult time removing the recessed can/dome. even if i could, it will be difficult to open the junction box and wire correctly as the ceiling hole is too tight and it would be too dark to see the wiring.
Old 03-08-2013, 05:06 PM   #11
Rewards Points: 93
also what is this connection? this is located on the side of recessed can. does this do anyting special? or this is also the same as wire connector.
Old 03-08-2013, 05:16 PM   #12
Oso954's Avatar
Rewards Points: 442
No, you can not electrical tape your ground wire to the can.
The "connector" you are wondering about is a thermocouple. It is designed to shut the can light off if it overheats.
Rip the can out. Install a ceiling box. Repair sheet rock, if necessary. Wire your trak light properly.
Oso954 is online now   Reply With Quote
Old 03-08-2013, 05:20 PM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
That is the thermal overload for the recessed fixture. looks like you have already cut it out.
Coastal South Carolina
Old 03-08-2013, 05:29 PM   #14
The junction box cover will remove by lifting a spring tab.
You can place a flashlight in the hole to see.
Old 03-08-2013, 06:37 PM   #15
Rewards Points: 93
but the recessed can is grounded, right? and i can tape the grounding wire of tracklight to the recessed can, right?
i'm not saying that's the proper way but it can be done like that, right?
Three romex into recessed light box - light won't turn off coopns Electrical 12 05-04-2012 08:27 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
Recessed Shower Light Ptron Electrical 3 10-05-2010 06:41 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 07:53 PM
