Recessed Cans For Outdoor Lighting, Spacing - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2009, 04:12 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Recessed Cans for Outdoor Lighting, Spacing
HI,
I guess this is more of a design question, rather than a technical electrical one, but I know that there will be people here with the experience to answer this.
I want to install recessed cans in the sofit along the front of my house. Is there a rule of thumb as to how far you normally space them out? I plan to use 6" cans. The sofit is about 8' off the ground, and there are 3' to 4' hedges below most of the sofit.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 04-11-2009, 05:37 PM   #2
dSilanskas's Avatar
How long is the area?
dSilanskas is offline   Reply With Quote
Old 04-11-2009, 09:13 PM   #3
DIY'er
jamiedolan's Avatar
In total the front of the house is almost 50', plus the attached garage is about 22', but it is recessed from the front of the house. So in total we have about 70' we are going to do the recessed lights for.
Jamie
Old 04-11-2009, 09:19 PM   #4
It depends upon how much light that you want
I have seen them spaced every 6-10' apart
I prefer hidden lights in the (behind) bushes pointed up VS soffits pointing down
Old 04-12-2009, 12:06 PM   #5
I wouldnt worry about even spacing of the cans as much as I would be more concerned about placement. You dont really want cans in front of windows, they look much better to left and right of of a window so they light up wall. So I would lay out how they fall taking windows and doors into consideration.
unclduey is offline   Reply With Quote
Old 04-12-2009, 10:12 PM   #6
Union Electrician
goose134's Avatar
good point.
goose134 is offline   Reply With Quote
Old 04-12-2009, 11:15 PM   #7
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Does anyone know if they make a recessed light to go in 2x6 gable ends?. I've seen some houses with lights in there gable ends (in the 2x6 ladder) but i havent been able to find a light that fits in under 5.5"
ryanh is offline   Reply With Quote
Old 04-13-2009, 04:18 PM   #8
DIY'er
jamiedolan's Avatar
Thanks for the responses. Very good point about the windows. I am going to have to take some measurements and draw this out with where the windows are to figure out where I can place them without making it look odd.
Thanks very much for the suggestions and point out the potential issue with windows.
Jamie
Recessed cans install billyg Electrical 9 06-03-2008 10:13 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
Recessed Cans fall right in the middle of my drywall seam... What do i do?? AndyH Building & Construction 20 03-13-2008 07:12 PM
Fluorescent lights to recessed cans. How do I determine where and how many? Bacardi 151 Electrical 13 11-06-2007 01:37 AM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
