Recessed Cans Install - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2008, 10:13 PM   #1
Recessed cans install
I am installing several IC (insulated ceiling) rated recessed cans. Due to the positioning of the cans in relation to the joists, some of the Cerro brand NM-B 14-2 600 volts wire will come in direct contact with the hot cans. (The cans do get hot to the touch with the recommended 75w Halogen bulb)--The wire will be tightly sandwiched between the can and a joist.
My concern is will the wire be able to handle the heat and if so, would installing it this way be within code? The can manufacturer, Halo, tells me no problem as long as the wire is rated at 90 degrees C. What do you guys say?
Should I chisel a recess in the joist for the wire to sit in and then cover the recess with a nail guard?--Or would that be a waste of time?
Thanks.
billyg is offline   Reply With Quote
Old 06-02-2008, 10:31 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
OK, I don't usu. do romex but I don't understand how, at 16" o.c., the cable would have to come into contact with the cans? Why not run it around the other side of the can???
Should I chisel a recess in the joist for the wire to sit in and then cover the recess with a nail guard?--Or would that be a waste of time?Thanks.
Oh god no. Please. Put the chisel down and move away from the poor, unsuspecting joist.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 06-03-2008, 04:39 AM   #3
use heat resistance sleeves to cover the wire. It can handle some considerable heat to protect wire.
mpj111 is offline   Reply With Quote
Old 06-03-2008, 05:33 AM   #4
Newbie,
Would the sleeves be the "heat shrink" type?--Looks like thin black tubing?
Thanks.
Old 06-03-2008, 04:59 PM   #5
Not the shrinking type,( they are mainly to cover the bear copper in order to insulate), There are sleeves available, do some shopping around in couple of electrical supplier.
Old 06-03-2008, 05:36 PM   #6
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
NM-B is rated at 90 degree C.
John
jrclen is offline   Reply With Quote
Old 06-03-2008, 07:19 PM   #7
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
NM is rated at 60 deg, 90 if derating 334.80. I could stand corrected but it's how I've always understood the article.
wirenut1110 is offline   Reply With Quote
Old 06-03-2008, 08:34 PM   #8
jbfan's Avatar
Rewards Points: 246
MN-B is rated for 90 degree C for derating, but you must use 60 degree C for ocpd.
Old 06-03-2008, 09:37 PM   #9
jrclen's Avatar
Rewards Points: 514
The OP stated the manufacturer said everything was fine if the conductors are rated at 90C. That is very common with light fixtures, and NM-B is rated at 90C for that purpose. No mention was made about ampacity or derating. Just the temperature rating of the insulation.
John
Old 06-03-2008, 11:13 PM   #10
Electrician
as already mentioned, just pick another route for the wire...
chris75 is offline   Reply With Quote
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
Recessed Cans fall right in the middle of my drywall seam... What do i do?? AndyH Building & Construction 20 03-13-2008 08:12 PM
Fluorescent lights to recessed cans. How do I determine where and how many? Bacardi 151 Electrical 13 11-06-2007 02:37 AM
Recessed light plan foiled? kcrossley2 Electrical 8 03-15-2007 12:08 AM
Can I Mount Can (recessed) Lights Vertical? jmaguire123 Electrical 9 11-28-2006 08:49 AM
