Recessed Cans Ic?? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 06:12 AM   #1
recessed cans ic??
I had an electrician install some ic rated recessed cans for me in an area that needs to be insulated. He said the type of cans he installed were fine for insulated area's. Well, when I went to replace the insualtion, I noticed the cans were labeled IC , but a sticker said NOT to put insulation within 3 inches of the housing?? What's the deal? The area is an outside overhang and has water lines running through the floor joists so it needs insulation. I thought I would be able to put insulation all over/around the recessed cans because the water lines are above?? Confused.
rakuz66 is offline   Reply With Quote
Old 04-14-2010, 08:26 AM   #2
Do you have a MFG/model number of the cans ?
Old 04-14-2010, 08:57 AM   #3
Progress P87-AT
Old 04-14-2010, 10:03 AM   #4
General Contractor
insulation options
I can't explain the contradictory labeling, but you could use non-flammable insulation products around the cans to be safe.
Dow makes a "great stuff" foam in a can product designed as a fire block and you can use rockwool in place of typical fiberglass around the bats.
Cheers,
R
Rory
RDG Read Development LLC
Portland, OR
Rory Read is offline   Reply With Quote
Old 04-14-2010, 10:36 AM   #5
I called Progress Lighting and asked about the label. They said these type cans were rated as IC or Non -IC, and I could put insulation all around the cans and to just pull off the labels. But, good point Rory about the Dow product. Don't know where I would find rockwool??
Old 04-14-2010, 03:08 PM   #6
General Contractor
Note that most of the "great stuff" is not fire block suitable. Only one type is. I realize my post could have been more clear.
I can get rock wool or mineral wool from my local, non home depot, builder supply yard.
Rory
Portland, OR
Need some guidance on recessed cans wiring..... TyWebb Electrical 6 02-17-2010 01:01 PM
Recessed lighting cans Mike in Arkansas Electrical 1 01-28-2010 06:06 AM
Recessed Cans for Outdoor Lighting, Spacing jamiedolan Electrical 7 04-13-2009 04:18 PM
Recessed cans install billyg Electrical 9 06-03-2008 10:13 PM
Recessed Cans fall right in the middle of my drywall seam... What do i do?? AndyH Building & Construction 20 03-13-2008 07:12 PM
