Recessed Cans - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 02:18 PM   #1
Electrical Enthusiast
Rewards Points: 504
Recessed Cans
The lights on my front porch are recessed cans, similar to this:
http://www.bing.com/images/search?q=...lectedIndex=79
They take a regular indoor floodlight bulb and are uncovered. I get aggravated because wasps love to make nests up inside the cans, along with dirt daubers, birds, etc. The trim around the lights is also starting to rust and look bad. I thought about replacing them with a trim with a cover, such as what might be used inside a shower. Is this feasible, or does it involve changing the whole fixture?
Kyle_in_rure is offline   Reply With Quote
Old 02-15-2013, 03:32 PM   #2
Rewards Points: 6
You can change just the trim. It should pull down out of the can. It should be held in with springs.
djlandkpl is offline   Reply With Quote
Old 02-15-2013, 03:36 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
If you use the shower trim, it reduces the wattage of the lamp.
Some as low as 40 watts.
Old 02-15-2013, 08:20 PM   #4
Rewards Points: 504
That's fine with me, if I do change the trim, I will probably use CFLs.
Old 02-15-2013, 09:31 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Use the LED trims. If you use an enclosed shower type trim, you are limited to a 60W A19 lamp (in most cases). The lamp combined with the trim will produce significantly less light.
Old 02-15-2013, 09:35 PM   #6
Rewards Points: 504
That's interesting. I'll consider that, too.
New IC rated recessed cans camner Electrical 8 05-22-2012 12:07 AM
Install New Work IC Recessed Cans in an Old Ceiling Sierevello Electrical 3 02-03-2011 02:01 AM
recessed cans ic?? rakuz66 Electrical 5 04-14-2010 04:08 PM
Need some guidance on recessed cans wiring..... TyWebb Electrical 6 02-17-2010 02:01 PM
Recessed cans install billyg Electrical 9 06-03-2008 11:13 PM
