Recessed Cannister Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2009, 10:12 AM   #1
When I install recessed cannister lighting do I need to run the wire to where the light is going to be prior to nailing the light into the basement joists? I am just wondering if the portal where the wire goes into the cannister is accessible after it is nailed in or if it would be easier to hook it up before I nailed it to the joist.
cambishop is offline   Reply With Quote
Old 10-28-2009, 11:59 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
It will be accessible after te cans are nailed.
Old 10-28-2009, 06:00 PM   #3
DIY staff
Rewards Points: 7,174
I usually install the fittings(bx or romex connectors)first. Easier on the ground I figure.
The little metal slide fittings can be removed and reinstalled a 1/4 turn if the access panel is inaccessible the way the hanger came from the factory.--MIKE--
Oh, Don't forget to lock the can to the hanger(set screw or crush a tab) so that they don't move when you install the drywall!
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Insulating IC recessed lighting. topher0524 General DIY Discussions 4 02-10-2009 07:03 AM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 10:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 03:52 PM
