Recessed Can Replacements, G24 CFL To LED. Wiring Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 09:53 AM   #1
Recessed can replacements, G24 CFL to LED. Wiring issues
I currently have recessed cans in my kitchen that use g24 cfl bulbs. I would like to replace them with LED retrofit kits from Ecosmart. These kits use an adapter with 2 wires on it (black and white) I replaced a few cans in another part of my home using these and it was quick and easy. Now that I've moved into the kitchen I'm not sure how the 4 wires in the cans will condense down to 2 or if that's possible. I can't remove the housings since they are new construction cans so I need to see what my options are.
Thanks in advance!
T-dog is offline   Reply With Quote
Old 04-08-2012, 10:00 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Those cans use a ballast to light the G24 lamp. You won't be able to use the retrofit kit without removing/disconnection and rewiring the can. That being said, if you do disconnect the ballast and rewire the can, you are changing the way the can was designed and thus voiding the listing.
Bottom line, those retrofit kits cannot be installed in those type cans legally unless the kits instructions specifically say they can be installed in that can.
Old 04-08-2012, 10:20 AM   #3
Thanks for the ultra fast response.
I'll wait until a kit comes out that is designed for my housings. I really hate the G24 bulbs. They are impossible to remove for some reason.i always end up breaking them and removing the remnants with needle nose plyers. Argh. Was hoping to be more green and less frustrated by using LEd's.
Old 04-08-2012, 10:56 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
You might want to look into GU24.
I had to look up G24....because I thought you really meant GU24.
GU24 is a different base that qualifies as high effeciency....you can get both CFL's and LED bulbs in that base type....
wiring recessed lights UFoPilot Electrical 1 03-31-2012 04:08 PM
Help Please ! heat pump tstat wiring issues Maybe? madmat276 HVAC 17 12-04-2010 01:58 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 02:10 PM
Leviton 8599 GFCI wiring issues Ultrarunner2017 Electrical 4 02-06-2009 09:53 AM
wiring for recessed lighting krw3153 Electrical 1 10-04-2005 02:39 PM
