Recessed Can Light Making Noise - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 08:29 PM   #1
Recessed Can light making noise
Awhile ago i installed two 6'' halo LED recessed can lights in my bedroom above my bed. I noticed that one of the lights makes a noise every now and then. Its not consistant but it is noticable when sitting in the room for a extended period of time.
The best way to discribe this noise i would say it is a single "clink"
the light is not shorting out or arching or flickering.
I would say it is just the metal in the can heating up and causing this noise. But only one light is doing it.
Anybody every hear of a can light making this "clinking" noise? or what might be going on?
Thanks.
Kenny101 is offline   Reply With Quote
Old 02-27-2012, 08:40 PM   #2
I pulled switch power off of the closest receptacle, witch also powers a few other things in this room. Tv and fish aquarium.
Could this be the issue? Should i have pulled power from a lighting circuit instead of the power circuit?
Old 02-27-2012, 08:48 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Does not sound like an electrical problem.
It could be the metal heating up, and a loose rivet or something in the can.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
DangerMouse (02-28-2012)
Old 02-27-2012, 08:51 PM   #4
Rewards Points: 582
that would be my guess seems like expanison in the fixture due to heat...
Old 02-27-2012, 09:21 PM   #5
thats what im thinking...I paid 80 somthing bucks a piece for these lights. I would think they would not have that issue...O well. its not bad and im probably the only person who will ever notice it. Just thought id see if anybody ever incountered this.
Old 02-27-2012, 09:32 PM   #6
LEDs are tricky from the manufacturing standpoint, because of heat issues --
My guess -- as you and others have also -- is the heat is causing this noise at some point --there's expansion / contraction going on.
Heat "sinking" is very critical to LED life performance -- I wonder if there's a difference between the 2 fixtures, and the heat sink is "loose?"
Will be interesting to know what you find out.
danster44 is offline   Reply With Quote
Old 02-27-2012, 11:25 PM   #7
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Swap the bulb between the one clicks and one that does not.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Replacing a chandelier with a recessed light. RyanD General DIY Discussions 5 01-19-2016 10:27 PM
Recessed Shower Light Ptron Electrical 3 10-05-2010 05:41 PM
Recessed light suggestions? vyjeff Electrical 1 04-27-2010 01:26 AM
Recessed light junction box question chris_k Electrical 1 04-21-2009 08:12 AM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
