Recess Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 11:06 AM   #1
recess lights
how many recess lights can I put on one 15 amp circuit? live in Delaware.
raineydr is offline   Reply With Quote
Old 04-05-2010, 11:10 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
What is the max wattage listed for the type of lamp and trim you are using?
jbfan is online now   Reply With Quote
Old 04-05-2010, 11:19 AM   #3
Master Electrician
Rewards Points: 3,870
I don't put over 1440 watts on a 15 amp lighting circuit. No more than 600 watts in the case of a dimmer except in rare instances that might require a 1000 watt dimmer which I try to avoid.
brric is offline   Reply With Quote
Old 04-05-2010, 11:48 AM   #4
It all depends on the dimmer. Standard incandescent dimmers are available in up to 2000W ratings. That said it is pretty uncommon in a residential application. That would also probably be in the neighborhood of 20+ recessed cans and odds are he won't need that many (if so please tell us what you're doing... I'm curious .
brich is offline   Reply With Quote
Old 04-05-2010, 12:18 PM   #5
I have installed 24 recess lights. 4 zones and 6 lights in each zone. Each is on its own separate dimmer switch which has a toggle on/off feature. I wanted to add 1-2 additional lights to one of the existing 6 light setups. I will have to check the packaging to tell you the actual max wattage.
Old 04-05-2010, 12:38 PM   #6
Master Electrician
Sounds good. 8 75 watt lamps equals 600 watts. 24 @ 75 watts equals 1800 watts. I would use 2 15 amp circuits or 1 20 amp circuit.
The Following User Says Thank You to brric For This Useful Post:
raineydr (04-05-2010)
Old 04-05-2010, 02:11 PM   #7
Electrician
Rudeboy's Avatar
Go with two 15a circuits and run 14awg wire.
Rudeboy is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
need help removing ceiling fan and installing recess lights craig83170 Electrical 1 09-06-2008 07:27 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
