Recess Lighting Spot Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2009, 02:54 PM   #1
Recess lighting spot not working
Hi everyone,
I have a recess spot light in my kitchen that is not working. I put in a new light bulb but nothing. Before it stopped working, it would "twitch" or flicker every few minutes, then it stopped working altogether. Tought it was the light bulb that was burned then tried a new box of lightbulbs also, still nothing.
What could be causing that? And is it something easy to fix or do I have to call in an electrician?
Thanks.
bellezza is offline   Reply With Quote
Old 11-11-2009, 03:19 PM   #2
300zx's Avatar
Post
Originally Posted by bellezza View Post
Hi everyone,
Thanks.
Is this only one recess light in kitchen if so could be the switch another thing TURN OFF POWER and then take bulb out and the center tab in light socket and pull it out a little.
300zx is offline   Reply With Quote
Old 11-11-2009, 03:31 PM   #3
Yes, it's the only one in the kitchen that doesn't work, all others are ok.
Sorry if I sound like a newbie in that area, I am !!
Old 11-11-2009, 03:55 PM   #4
300zx's Avatar
Post
one the can lighting there are 1/4 screws that hole the can in place there are two options here if you know how they are wired the last on that is working you could take it apart and check the conections othe option take apart light that is not working and make sure it is getting power (use a tester)if its getting power you prob need to buy a new can and replace it with the old one.
Old 11-11-2009, 07:04 PM   #5
Household Handyman
Rewards Points: 1,408
I'm with 300zx on this one--a lot of times when a light flickers, the lamp is screwed into the socket as far as it will go, but--the spot on the end of the lamp is barely touching the little metal strip within the lamp socket. This little tab will warm up with the lamp on and bend, sometimes bending so as to break the connection and the lamp goes out. As soon as the lamp goes out, the metal tab cools down just enough to make contact again and lamp on. DO, please DO, turn off the power to the light fixture before trying to adjust the tab inside the lamp socket. AND--only pull it down just a little bit. IF this does not solve the problem, then the wiring for the fixture needs to be checked out. Good Luck, David
Recess lighting in series? genner Electrical 12 02-23-2009 05:55 AM
Recess Lighting Lucci_42 Electrical 2 12-03-2008 02:17 PM
under cabnet lighting not working The Barber Electrical 3 07-09-2008 03:31 PM
non-ic recess lighting jvmagic Electrical 6 02-21-2007 04:10 PM
Installing recess lighting spyguy Electrical 14 01-18-2007 08:28 AM
