Recess Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 11:32 PM   #1
Recess lighting
We are putting in 6 inch recess lights in our basement. Not sure how many to put? The area is about 20' by 24'? It is all one open area but we are putting a tv area in one part which is about 10' by 14' and the other area is just a game room. Any advice will help?
hockey21 is offline   Reply With Quote
Old 02-11-2011, 11:39 PM   #2
If our going to feed them off a new circuit from the panel (20amp ) you can run as many as 12-15 safely , you can put them on dimmers also to get the mood right . If an existing circuit is feeding them you better use an amp probe to find the load on it and go from there.
PJMark is offline   Reply With Quote
Old 02-12-2011, 02:35 AM   #3
" Euro " electrician
frenchelectrican's Avatar
How high this basement ceiling will be at ?
Typically for that size room useally 12 to 18* with BR65 bulbs for other size bulb it may change a bit.
And if you are plan to use the dimmer make sure you have proper sized dimmer to handle the load of the luminaires { I always go with max wattage it listed the luminaire }
Merci.
Marc
* all it depending on bulb , trim both will affect in some degree and the surface reflectiotive is.
Recess lighting spot not working bellezza Electrical 4 11-11-2009 08:04 PM
Recess lighting in series? genner Electrical 12 02-23-2009 06:55 AM
Recess Lighting Lucci_42 Electrical 2 12-03-2008 03:17 PM
non-ic recess lighting jvmagic Electrical 6 02-21-2007 05:10 PM
Installing recess lighting spyguy Electrical 14 01-18-2007 09:28 AM
