Old 03-13-2009, 03:46 PM   #1
Recepticle doesn't have enough power?
Hey guys..
I have 1 electrical recepticle in a bedroom which isn't supplying "enough" juice. Meaning, the light tester comes up VERY dim once I test it, though the rest of the house comes through with a very BRIGHT light on the test. Also, anything I plug into this outlet doesn't power up.
After shutting off the breaker, I checked out the recepticle and it has 1 white wire, and 1 black wire connected to it, I even changed the recepticle unit with a working one, and the same dillema occurs. Any ideas?
slaya is offline   Reply With Quote
Old 03-13-2009, 05:02 PM   #2
Electrical Contractor
You need to check the outlet that feeds that one.
It may have a loose connection.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-13-2009, 05:29 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Depending on your type of tester (neon?), it may not be connected at all.
Old 03-14-2009, 12:46 AM   #4
Thanks dude, that was it. there was a loose connection at the recepticle leading to that one.
Old 03-14-2009, 10:36 AM   #5
No Problem! Thats why we come here!
How do I get power to a new ceiling fan? sestivers Electrical 12 04-25-2011 03:11 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
