-   -   Recepticle doesn't have enough power? (http://www.diychatroom.com/f18/recepticle-doesnt-have-enough-power-40250/)
slaya 03-13-2009 02:46 PM
Hey guys..
I have 1 electrical recepticle in a bedroom which isn't supplying "enough" juice. Meaning, the light tester comes up VERY dim once I test it, though the rest of the house comes through with a very BRIGHT light on the test. Also, anything I plug into this outlet doesn't power up.
After shutting off the breaker, I checked out the recepticle and it has 1 white wire, and 1 black wire connected to it, I even changed the recepticle unit with a working one, and the same dillema occurs. Any ideas?
jbfan 03-13-2009 04:02 PM
You need to check the outlet that feeds that one.
It may have a loose connection.
Yoyizit 03-13-2009 04:29 PM
Depending on your type of tester (neon?), it may not be connected at all.
slaya 03-13-2009 11:46 PM
Thanks dude, that was it. there was a loose connection at the recepticle leading to that one. :)
jbfan 03-14-2009 09:36 AM
No Problem! Thats why we come here!:thumbsup:
