Recepticale Wiring /new Construction - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 05:19 PM   #1
recepticale wiring /new construction
Hello Friends,
I am finishing my basement and I need to supply my local inspector with a wiring diagram that meets 2011 NEC. I have ran wire and replaced recepticles before so I know how to do the work, just not knowledgable on the exact codes. I have read through most of the 2011 NEC but I am having trouble finding all the information I need, specifically:
1. How far from recepticale does first staple have to be? 6"??
2. Size of NM recepticale box? I plan to use 3 5/16 x 3 1/2 x 2 1/4 (i'll using 14/3 and 12/3
3. He said something about free space???
4. How much jacket has to left on wiring when visible in box?
5. Staples every 2', correct??
6. Receticles every 6' or 8' horizontally?
7. I have them set at 16" from floor
8. I plan to use an outlet branch circuit AFCI at the first recepticle on each circuit. Is this sufficient or do I need a AFCI breaker as well??
Does anyone have link to a pic or simple diagram that would include all of this info?? Any links would be very helpfull.
Greatly appreciated,
SC
Stcrosby is offline   Reply With Quote
Old 03-28-2013, 05:30 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Stcrosby View Post
I have read through most of the 2011 NEC...
This should answer most of the questions:
http://www.nojolt.com/residential_el...in_guide.shtml
Old 03-28-2013, 05:34 PM   #3
Licensed electrician
Rewards Points: 1,502
Hello Friends,
1. How far from recepticale does first staple have to be? 6"?? Within 8" without a clamp, or within 12" with a clamp.
2. Size of NM recepticale box? I plan to use 3 5/16 x 3 1/2 x 2 1/4 (i'll using 14/3 and 12/3. Deeper boxes allow more room to work and for more conductors.
3. He said something about free space??? Boxes are rated for a certain number of conductors. They need to be big enough for all the conductors.
4. How much jacket has to left on wiring when visible in box? At least 1/4"
5. Staples every 2', correct?? No more than 4 1/2' between.
6. Receticles every 6' or 8' horizontally? No more than 12' between
7. I have them set at 16" from floor Your choice.
8. I plan to use an outlet branch circuit AFCI at the first recepticle on each circuit. Is this sufficient or do I need a AFCI breaker as well?? AFCI receptacles are just hitting the market. The breaker would be easier.
SC
Answers in blue.
Old 03-28-2013, 07:25 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
In New Jersey since you are finishing off a basement the work falls under the ReHab Subcode. Follow the links in my signature to a thread I started for DIY in New Jersey. If you need additional info post your questions here.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-28-2013, 11:33 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Hello Friends,
With some of the single gang plastique boxes without clamp it will be max of 8 inches or two gang plastique or any metal box with extreral clamps max is 12 inches beside the metal boxes with interal clamps it will be the max of 8 inches.
The size of the box you are describing that sound like a single gang verison so therefore get the deepest one you can find. ( the deep verison will useally about 22 Ci size compared to standard one can hit about 18 Cu inches so that make the differnce.
Just make sure you don't over crowed the junciton boxes at all.
Minuim of 1/4 inches and make sure you have the conductor come out about 6 inches from the point of entrance of junciton box.
Max of 4 to 4.5 feet you can have it little closer if needed to. but do not overdrive them in the boards ( if get too deep it can actually cut the insulating materals and can cause a short circuit right there.)
Max of 12 feet apart with any unbroken wall more than 2 feet ( check with your local codes for minium witdth )
Your call but try to keep the same as upstair if possible
Genrally AFCI breakers are avaiable but the AFIC receptale device what I heard they just came out that part I do not know what the cost will be so it will be better off just get AFCI breaker.
SC
My reply in green
Also double check with Electures's link with the latest code on your state which he will give you a good infomation related to the latest edition of the state codes so that will give you the best answer on that.
The other thing I want to give you a head up if you going to use recessed luminaries ( if ever happend ) please size the circuit by max wattage of the recessed luminaire which it will be listed inside the luminaire can.
If you have more question just go ahead and posted in here one of us will reply to ya.
Bon Chance!
Merci,
Marc
Old 03-29-2013, 06:06 AM   #6
Rewards Points: 748
SC
If you really read through MOST of the 2011 NEC, you shouldn't still have all of these questions.
Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
Speedy Petey (03-29-2013)
Old 03-29-2013, 06:13 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
While AFCI receptacles are basically brand new to the market and I wouldn't touch them with a 10' pole, there are some very specific requirements using the device over a breaker.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
brric (03-29-2013), frenchelectrican (03-29-2013), Speedy Petey (03-29-2013)
Old 03-29-2013, 06:24 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
Fully agree.
In the average wired home an AFCI receptacle would NOT satisfy code.
Speedy Petey is online now   Reply With Quote
Old 03-29-2013, 09:31 AM   #9
Electrical Enthusiast
Rewards Points: 504
Originally Posted by Speedy Petey
Fully agree.
I'll second this.
Use an AFCI breaker; an AFCI receptacle might not satisfy code because the entire length of cable would not be protected.
Kyle_in_rure is offline   Reply With Quote
Old 04-07-2013, 02:21 PM   #10
Thanks for all the help guys.
I opted for AFCI breakers on all circuits except bathroom and laundry room.
Old 04-07-2013, 02:42 PM   #11
Mark
touche....
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 08:49 PM
