Receptical Short - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2013, 07:17 PM   #1
Receptical Short
Went to a friend's house, called and said the breaker to an outside receptical trips after about 10 minutes with nothing plugged into it. Her brother-in-law replaced the receptical and box and relocated it about 2 feet so it would be under the overhang a few weeks before. I took the cover off and checked wiring and seen no problems, it was wired correctly. I put the cover back on, turned the breaker on and plugged a neon lamp into it. About 10 minutes later it tripped but this time I heard a POOF noise. I checked inside the box again, it was stlll okay and did not see or smell any electrical burn. Then it was discovered that about 6 recepticals inside the house were not working. They were in 3 different rooms at the opposite end of the house on different breakers from the one that was tripping. Their breakers were not tripped.
mustang08 is offline   Reply With Quote
Old 09-04-2013, 07:29 PM   #2
Rewards Points: 150
Is the breaker by chance a gfi breaker?
romex1220 is offline   Reply With Quote
Old 09-04-2013, 07:50 PM   #3
No, just a regular brown receptical.
Old 09-04-2013, 08:11 PM   #4
Rewards Points: 150
I meant the breaker
Old 09-04-2013, 08:17 PM   #5
No, it is a regular breaker.
Old 09-04-2013, 08:40 PM   #6
Rewards Points: 150
What else is on that breaker that does the outside plug
Old 09-04-2013, 09:09 PM   #7
Two GFCI recepticals around the deck with nothing plugged into them.
Old 09-04-2013, 09:14 PM   #8
joed's Avatar
Rewards Points: 12,388
Did you check the old receptacle location? Is there a junction box to extend the cable to the new location? Are the connections good in the junction box?
Old 09-04-2013, 09:59 PM   #9
kevinp22's Avatar
Try turning the breaker back on and see if those "other" receptacles work when the breaker is on. the fact that they don't work may or may not be related to the original issue. Also, does the breaker trip if noting is plugged into the receptacle?
kevinp22 is offline   Reply With Quote
Old 09-05-2013, 05:20 AM   #10
dmxtothemax's Avatar
Rewards Points: 5,178
Could be one of the hots coming into your panel might have a intermittant
drop out,
Loose connection or faulty switch/breaker.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
mustang08 (09-05-2013)
Old 09-05-2013, 06:46 AM   #11
There is no jusction box for the new location, the existing wire was long enough. I checked connections in the receptical box and they are good.
Yes, I turned the breaker back on and the "other" recepticals were still dead.
I checked all connections in the panel and switches and they were good.
Old 09-05-2013, 06:52 AM   #12
Yes, it trips with nothing plugged in.
Old 09-05-2013, 07:07 AM   #13
Resi EC
Rewards Points: 252
Did the breaker trip before the receptacle was moved?
Does the breaker in question turn anything else off?
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 09-05-2013, 07:14 AM   #14
Electrical Enthusiast
Rewards Points: 504
I find this surprising. What is now where the old receptacle was?
Kyle_in_rure is offline   Reply With Quote
Old 09-05-2013, 07:15 AM   #15
PoleCat's Avatar
Rewards Points: 1,646
Shared neutral wire?
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Bryant Furnace short cycling...help! Spark Chaser HVAC 12 04-06-2016 08:16 PM
Furnace short cycling repman55 HVAC 12 01-21-2011 04:41 AM
Short Wires in an Overfill HooKooDooKu Electrical 34 01-31-2010 12:18 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 12:54 PM
I caused a short in one room - now what? taychas Electrical 6 11-08-2006 04:02 PM
