Receptacles In An Unfinished Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 09:08 PM   #1
Receptacles in an unfinished basement
In an unfinished basement do have to use conduit when wiring receptacles, or can I screw pieces of 1x4 wood to the concrete and then just staple the romex to it. Then the romex going through a romex connector into a handy box. Can this romex be exposed like this?
J. Guinness is offline   Reply With Quote
Old 10-07-2012, 09:12 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Some people say yes, around my parts (WI) that would not fly. Remember, all receptacles in an unfinished basement must be GFI protected.
Old 10-08-2012, 10:25 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Goes both ways. If the romex will be subjected to physical damage, then conduit is needed. Otherwise, staple it down the board. Avoid putting more than one cable in a handy box as boxfill is a consideration.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-08-2012, 12:08 PM   #4
Rewards Points: 2,516
You can sleeve the romex thru the EMT for the vertical drop to the box
Receptacles in an unfinished basement-sleeve.jpg   Receptacles in an unfinished basement-sleeve2.jpg   Receptacles in an unfinished basement-100_8317.jpg
hammerlane is offline   Reply With Quote
Old 10-08-2012, 12:30 PM   #5
Hammer
Hammer, you say I CAN run it in conduit, But do I HAVE to run in in conduit? Is it permissable by code to have the romex exposed leading down to the box, just stapled to a 1x4 strip of wood?
Old 10-08-2012, 01:17 PM   #6
Master Electrician
Call your local inspector office. This is an area that's solely up to the inspectors definition of subject to physical damage
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-08-2012, 01:30 PM   #7
Horizontall speaking...If you're not using bored holes, or cable 6-2, 8-3, or larger, then running the cable on running boards is the only acceptable exposed NM wiring method in an unfinished basement or crawlspace.
but as Andrew suggested talk to local inspector about doing that on a vertical surface.
Receptacles in an unfinished basement-runboard.jpg   Receptacles in an unfinished basement-runboard2.jpg
unfinished basement comfort tls1 HVAC 44 09-16-2012 11:44 AM
Adding wall outlets, unfinished basement cferg68 Electrical 9 07-12-2012 11:46 AM
Unfinished basement, GFCI and phantom trips whatrymes Electrical 3 11-24-2011 10:36 AM
Framing in an unfinished basement benb Carpentry 3 02-15-2011 10:27 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
