Receptacles/Sockets Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 05:51 PM   #1
Unhappy
Receptacles/Sockets stopped working
There must be a simple reason why electrical wall sockets stop working suddenly. I've checked the circuit breakers and none were off but I reset them anyway. They are just regular wall sockets, not GFI, not near water. come to think of it, since these two in the kitchen have stopped working, there are a couple in the finished basement that have never worked since I moved in here. Thanks.
BuffaloWinters is offline   Reply With Quote
Old 01-31-2010, 06:04 PM   #2
Remodeling Contractor
Seems that this strange thing happens with everything that breaks. It worked right before it did not work? Just need to start troubleshooting the problem. Where does it not work and where does it work. Is there wire backstabbed into one outlet near it that works? This is one area that may cause this. Or the wire broke from a staple that was too tight and the heat of using the circuit finally weakened it enough to break.
Old 01-31-2010, 06:51 PM   #3
" Euro " electrician
frenchelectrican's Avatar
First thing you have to do is check few other spots where the GFCI receptale may show up they will show up in odd place look behind the frezzer or other place you never think in normal fashion.
Once you verifed then you may have a connetion issue with one of the receptale backstabbed recepetales are most common cuprit.
Merci,Marc
Old 01-31-2010, 09:41 PM   #4
Thanks for the response. I learned what backstabbing is from another forum, and if I'm correct it is a go-around to a more proper installation that does not use the screws on the receptacle. So given that, if that is indeed the problem, then replacing the receptacles should resolve the problem.
And thanks for the tip about a GFCI that I hadn't noticed. I'll check for that first.
Old 01-31-2010, 10:15 PM   #5
Thumbs up
My answer might be slightly off topic. But the top line of your post is sooo funny. We have an elder statesman (and former Sports Team Manager) in New York State, named Yogi Berra, who coined phrases that became Classics through their simplicity. One example is the phrase, when a game didn't go very well; "It Ain't Over Till It's Over"! Well. From a Philosophical point of view it's very funny. "Everything worked till it sopped working". But you're 100% right that there are no shortcuts in troubleshooting. It's a lot of tedious work. But some common sense has to be applied. Where to start looking for the problem. Interestingly, it was determined (by the testing labs or by the reports of failed connections) that the "Backstabbing" method has a high failure rate, especially with #12 wire. As a consequence, the Manufacturers have made it impossible to insert #12 in the "Quick-Connect" terminal. The wire can only be wrapped around the Screws!!
spark plug is offline   Reply With Quote
Old 01-31-2010, 10:17 PM   #6
And that is the answer I gave them
Old 01-31-2010, 10:25 PM   #7
Thumbs up
Just enhancing your advice. But the phrases coined by Yogi Berra are so much fun. I think there is a website that lists them all.!
2 lights stopped working! ohwinnipeg Electrical 13 01-12-2010 11:18 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 07:12 PM
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 09:38 PM
Outlet stopped working nealt Electrical 9 07-19-2008 04:46 PM
Light Stopped Working gershon Electrical 5 01-10-2007 09:03 PM
